RooDude09
Santa Rosa, CA
It's been driving me crazy with our 2010 Keystone Hideout. I could have sworn with my analog tv with converter in the old Roo that I got reception at least one of the camp sites we normally go to but with the Hideout with digital flat screen I find absolutely nothing when camping. I have received a couple public access channels where we store it though. Do the trailer antennas just
t not pick anything up anymore or is there a problem?
Dirtclods
Newport Beach
Mine works fine! Did you push your power button in for your antenna?
Old-Biscuit
Across the USA
Locate direction of TV Transponders
Aim antenna towards them
Turn on antenna amplifier.....'booster'
Select 'over the air', 'antenna' etc. on TV menu for tuner
Auto scan for available channels
Repeat when/if you move RV to different location
Digital Signal Locator
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
RooDude09
Santa Rosa, CA
Did all that. I wonder how to check if the booster is working.
RJsfishin
Winston Or.
You should get every channel that you were getting clearly before digital.
But I know I completely lost a lot of them that were snowy but watchable before digital.
Rich
'01 31 ft Rexall Vision, Generac 5.5k, 9245 conv, 400 watt inv, 2 12v batts, ammeters, KingDome/sat, Two Oly Cat heaters, and towing a '05 Jeep Liberty, or sometimes towing a Lowe bass boat.
HouseApe
Vancouver
Try tvfool
http://www.tvfool.com/
it will tell you what you should get and where to point your antena.
2007 Dodge Megacab Laramie 4x4 5.9 Cummins
2008 Cougar 301BHS
Reese Straight Line
Tekonsha P3
LarryJM
NoVa
RJsfishin wrote: You should get every channel that you were getting clearly before digital.
WRONG and that shows you don't understand what happened with the conversion. A lot of channels when from VHF to UHF and while UHF works great it's range is less than VHF where most of the old channels were and they greately reduced the UHF transmit power.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
D.E.Bishop
Eagle Rock, CA
With a DMM check the potential between the outside shielding and the center conductor. With the booster on, you should read 12-13
Check the potential between the inside copper core and the shieding on the cable at the antenna. With the booster on it should read 12-13 VDC. Go somewhere you know there is good signal and run setup on your TV and see if you have signal. If you do the antenna is working. I find that with the converter box I get more stations now than I did when the stations were analog.
vdc
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
1990 Bounder 27D
1995 Suzuki Sidekick 4X4
Stowmaster 5000
Richmcm
Philadelphia, PA, USA
I get more channels than ever before and with much better quality in most situations I use it. The only thing I added to the batwing was the digital extension and that did a decent job of producing channels.
Rich & Diane
2006 Aspect 26 A
Nitro 640 LX
AtomicChicken
Central Louisiana
Something else to consider. The issue I had was from a year ago I wasn't catching nearly the same number of channels that I had been. Come to find out the coax connection at the antenna itself had managed to work itself loose. After tightening that up everything was back to normal.
2007 F-150
2006 Sun Valley RoadRunner 240BH
Prodigy P2 / EAZ-Lift WDH
