RV.Net Open Roads Forum: Tech Issues: Leaking External Shower Connector
 > Leaking External Shower Connector
dboliek1112
Perryville, AR & Raleigh, NC
Posted: 07/08/12 10:55am Link  |  Quote  |  Print  |  Notify Moderator
This is something I probably should know, but don't. We have a new to us 2000 Winnebago Chieftain 35U. In the water/sewer bay is an external shower. The faucets seem to be made by Phoenix. The outflow connector where the shower hose screws on in kind of an "L" shaped thingie... part number 91L5 VAC.
The problem is that when the shower is turned on water flows from the bottom of the valve as it should, but there is also a small hole at the top where water also comes out, flooding the bay. To me this is not a good thing. Is this just a bad part that needs to be replaced? Should I plug the hole on top?
Picture link below. Tried to insert pic, but didn't make it. Thanks for any thoughts.
Picture Link
* This post was edited 07/08/12 11:44am by dboliek1112 *
"The only thing more expensive than education is ignorance." Benjamin Franklin
Dave and Missy Boliek
Roxeanne and Maggie Moo Pie
2007 Saturn Aura
netaq
Atlanta, GA
Posted: 07/08/12 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
I'd rough up the fitting and mix up some jb weld to cover up the hole. Leaks of any kind can cause huge problems and should be corrected.
2012 Ford F-250 XLT 6.2 FX4
2012 Keystone Cougar HC321RES
netaq
Atlanta, GA
Posted: 07/08/12 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
Here's the image:
Old-Biscuit
Across the USA
Posted: 07/08/12 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
That's a vacuum breaker that shouldn't be leaking water out but allowing air end when you shut off shower. It's broke.....and is part of the faucet.
Time for a new faucet.........unfortunately the cheapo RV style of faucets (with the shower hose connection etc.) like you have are the only replacements.
Cheap for cheap......except pricing!
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
dboliek1112
Posted: 07/08/12 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the response. I hear you on pricing.
Dutch_12078
Great Sacandaga Lake, NY
Posted: 07/08/12 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
The vacuum breaker ("D-spud connector") is a readily available part at most RV dealers. Here's one online source that has it for $4.19:
VACUUM BREAKER D-SPUD, WHITE
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
DQDan
Boulder, Colorado, USA
Posted: 07/09/12 12:40am Link  |  Quote  |  Print  |  Notify Moderator
yep, it's a defective $5 vacuum breaker. It is threaded & screws in. No need to replace any other parts. Just put a small open end wrench on it & screw it out. Take the part to RV store & replace. I also had one of these go bad in the shower in my RV. Same symptom, squirts water out the hole. It went bad over the winter. later...dan
2005 PSD CC LB Lariat w/Tow Boss
2002 National Palisade 361
Timbren SES
Pullrite superglide 16K
Hughes Autoformer
Direcway 6000 portable satellite dish6000
SCClockDr
SC UpState
Posted: 07/09/12 07:12am Link  |  Quote  |  Print  |  Notify Moderator
I would think the spud pointed up is the more common install. I can't recall ever seeing one protrude from the bottom as yours does. If the ball indeed floats then up would seem a better way to go.
There is a small ball check valve which is supposed to block the air hole under pressure and allow air to enter when pressure is removed. If the spud freezes the short pipe can crack and spew water which deflects off the hole area and make it appear to be the hole leaking. Lime, crud, etc. can also prevent a good seal.
While it would be a bit of a project, it can be flipped by reversing the hot & cold connections & reversing the handle inserts.
George & Cathy
08 Titanium 28E33SA, XM, Honda EU 3000is, Trimetric, RotoChocks, LP Reg. Mod, PD 9260 Upgrade, 2 Gal Accum., WiFiRanger GO/Mobile/SKY
04 Ram 3500 5.9 DRW, PAC PRXB E/B, 4" MBRP SS Exhaust, Gauges, Aux Tank/box, BrakeSmart, Cobra (19).
USN Ret
dboliek1112
Posted: 07/09/12 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Thanks folks. The spud is missing the ball. Previous owners must have taken it apart and not put it back together correctly. I'll check my local rv shop. Best to you.
dave
