n4hwl
Murfreesboro,TN
I have a dometic model NDR-1292 ref. I took the vent cover off on the roof and noticed 2 12 volt fans mounted on the back of the refrigerator pointing up. I have never heard these fans come on. In really hot weather I would like to see these fan run. I found a 1 amp fuse inside the side access panel blown that looks like it may power these fans. When I replaces it the fan still will not come on. I also see what may be a termister mounted to the fins at the top that may be connected to these fans but I can not be sure. Things are hard to see up there. How do these fans work. I do not see any evidence that these fans have ever come on by the dirt ect. sitting on top of the blades. This is a 2004 Phaeton.
Thanks
Ken
2004 QDH 40ft Phaeton, Blue Ox Tru-Center
Ham Call N4HWL, TS performance mp-8
Kirk
Livingston, Texas.
I don't have access to a service manual for that refrigerator so can't tell exactly how it is wired but most likely it does have some type of thermostat control. If it were mine I would first tray supplying power to the fans with jumpers to see if they will run. It would not be that difficult to wire in a new power supply and thermostat to control them. The alternative would be to find a schematic and figure out how it is supposed to operate.
Perhaps if Chris Bryant is reading the forums he may have access to a service manual to determine just how that fan circuit is wired?
Good travelin! ........Kirk
Professional Volunteer
Fulltimer for 11 years,
URL: www.adventure.1tree.net
Old-Biscuit
Across the USA
Call Dometic at 800-544-4881
Have them send you instruction sheet for 'Power Vent Assembly' (part #3104131.002)
Service Manual only references them....no details/info
Service Manual
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
dougrainer
Carrolton, Texas
The tstat for the fans is bad. The tstat for the fans is located on the top condensor fins on 1 side and will be a small snap disc. COMMON problem. When replacing the tstat, run a 2 wire harness from the 2 tstat wires down the back to the rear bottom access of the refer. Install a switch on those 2 wires. That way you can run those fans all the time and if the tstat fails you can then run the fans. IF the fans are not running, you are not cooling as best as you can. Doug
Norskeman
Oswego, New York
I think the fans are used on fridges that do not have a vent on the roof (only "doors' on the side of the trailer).They will run based upon operating temp.
My trailer has a lower access door and an upper access door. When they fans run they have a high pitch sound.
I think mine run all the time when the outside air temp is about 70 degrees. They continue to run when I turn off the fridge until the unit cools down.
2012 Cruiser Patriot CF335SS fifth wheel.
TV - 2011 Chevy Silverado 3500HD LTZ CCLB Duramax SRW 4X4
Aahhyes68
Birmingham, MI
I've replaced that thermostatic snap-disc/klixon twice on our Dometic. I just installed a toggle switch in the lower access door (outside) and just flip it to on when it's +70 out. It was easy to tell when the klixon failed...the fridge would run at 50F....
2009 Cardinal 38BHQSLE
2008 GMC 3500/CC/D/A
DW,DD & two DS's. Life is good
dougrainer
Carrolton, Texas
Norskeman wrote: I think the fans are used on fridges that do not have a vent on the roof (only "doors' on the side of the trailer).They will run based upon operating temp.
Not correct. Fans are used when the parameters require a good flow of air up the back over the coils, when regular convection air cannot do the job. Doug
n4hwl
Murfreesboro,TN
My thermostat was bad. I wired these 2 fans to a switch inside the motorhome and now I can turn them on anytime and not have to depend on the undependable thermostat.
Ken
