RV.Net Open Roads Forum: Tech Issues: MH propane fill issues
 > MH propane fill issues
Beverley&Ken
Tottenham,Ontario
Posted: 07/08/12 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
After returning from a camping trip last Friday, I tried to get the propane cylinder (permanently attached) refilled, the gauge was reading about 1/3 tank, water heater has been on for 8 weeks, fridge while travelling and at least 4 nights of furnace use, plus some cooking.
They could only put in $4.00 worth of propane (5 litres, our way of measuring), before it indicated full, coming out overflow. The gauge still reads 1/3.
My question is, could the ambient air temperature 41c about 100 degrees, be the reason they could not add anymore propane to the tank?
Beverley and Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
Kirk
Livingston, Texas.
Posted: 07/08/12 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
Temperature should not cause that problem. I would suspect first an operator who didn't know what he is doing. I suggest that you try a second propane supplier but you might be wise to do so at a propane dealer who also has a service department. The other thing is that it could also be a problem with the gauge, which is a mechanical float type, but that is not likely based upon the usage that you report.
The propane in the tank which floats the gauge is in liquid form and while the outside temperature could influence the pressure inside of the tank a small amount, it would not change the level of the liquid significantly.
Good travelin! ........Kirk
Professional Volunteer
Fulltimer for 11 years,
URL: www.adventure.1tree.net
HappyKayakers
Black River Falls WI
Posted: 07/08/12 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
Did you observe the filling operation? Just wondering what came out of the overflow valve - vapor or liquid.
Joe and Dakota, the wacko cat
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2006 Heartland Bighorn 3600RL, MorRyde suspension, TrailAir pinbox
http://happykayakers.com/blogger/
Beverley&Ken
Tottenham,Ontario
Posted: 07/08/12 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
It appeared to be a vapour to me, but she would not try any more.
I will wait a while longer and then go back. Finding another dealer is not the best option, next one is 40 miles one way. Ontario gov't has put a lot of propane refill stations out of business with new regulations and inspections, google Sunrise Propane explosion Toronto.
Beverley and Ken
Old-Biscuit
Across the USA
Posted: 07/08/12 10:32pm Link  |  Quote  |  Print  |  Notify Moderator
Vapor will come out anytime you open bled screw......tank isn't full until liquid comes out.
Attendant needs to get better trained...all the regs/restrictions/inspections won't stop poorly trained operators
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
sc3283
St Louis
Posted: 07/21/12 01:06am Link  |  Quote  |  Print  |  Notify Moderator
I believe most "made in vehicle" LP tanks have a shut off incorporated into the fill valve...the bleed is just an added safety precaution. I know mine when being filled has an audible "click" and stops taking LP..the click occurs right at same time the bleed begins to push liquid.
04 D-Max Crew Dually
96 Monaco Dynasty 36'
Dutch_12078
Great Sacandaga Lake, NY
Posted: 07/21/12 06:45am Link  |  Quote  |  Print  |  Notify Moderator
The bleeder valve is the intended tank full indicating device, with the OPD (Overfill Prevention Device) as a safety backup. The technical name for the bleeder is the "Fixed Liquid Level Gauge".
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
Dusty R
Charlotte Michigan 48813
Posted: 07/21/12 06:46am Link  |  Quote  |  Print  |  Notify Moderator
I forget how but something about the gauge needle being connected to the gauge float with a magnet and can be off.
Maybe someone will post how or try doing a search on LP gauge.
Good Luck
Dusty
kneal44
EAST CENTRAL TEXAS
Posted: 07/21/12 07:34am Link  |  Quote  |  Print  |  Notify Moderator
use what you got till next fill up.. if the gauge is falulty and out of calibration you will get the same results on fill up.
my gauge reads one half at full tank so i live with it.... its a pain to replace.
on my float. there are bevel gears that may have slipped a tooth or two..
not worth the effort to replace.
i refill every trip.... when my gauge indicates empty i still have several gallons.
when u play in the sand .... you can get stuck
9-24-08 corpus christi padre island texas. wrecker had to haul me out!
'92 dp 5.9 cummins 190 hp....8mpg yuck!
red31
Bryan
Posted: 07/21/12 07:47am Link  |  Quote  |  Print  |  Notify Moderator
Could be, propane vapor pressure vs temp, if their pump is inadequate.
I had something similar happen at Yellowstone, 58 gallon tank, Chevy S-10.
The first filler hooked up, turned on the pump and their lines filled, the tank was not accepting propane. Second filler hooked up and was able to fill my tank.
