RV.Net Open Roads Forum: Class A Motorhomes: Whats your toad
 > Whats your toad
Page of 10
booty51
houston
Posted: 07/09/12 05:06am Link  |  Quote  |  Print  |  Notify Moderator
I tow a jeep wrangler it about 4400# we tow four down its an easy set up, xfer case in neutral and your set to go. My question is what do you tow and how,(four down , trailer , car dolly) and what had to be done to make it towable,( modifications to drive line) etc.
randco
Somewhere in time
Posted: 07/09/12 05:16am Link  |  Quote  |  Print  |  Notify Moderator
2004 Buick Rendezvous
4 down
Remco Lube Pump
Roadmaster Sterling All Terrain towbar and brackets
peaches&cream
Northwest Georgia
Posted: 07/09/12 05:18am Link  |  Quote  |  Print  |  Notify Moderator
I have towed a 1995 Mazda Miata over 10,000 miles. I tow it 4 down. Just put it in neutral and release the steering. Weight about 2200 lbs. I use brake buddy for supplemental braking and have the signals wired into the Miata so the lights work as commanded by MH. Use a Roadmaster tow bar and brackets. I Have towed it from Ga. to Ca. and back 2 times along with many other shorter trips. Great toad for 2 people plus our Pug.
2005 Holiday Rambler Ambassdor, 36PRT, 330 Cummings
Toad 1995 Miata
JayGee
Foothills of the Smokies
Posted: 07/09/12 05:45am Link  |  Quote  |  Print  |  Notify Moderator
2001 Honda Accord towed 4 down. Steering unlocked, radio, air blower, etc. turned off. Prep requires that engine started and idled for at least three minutes before towing and every 3-4 hours. I run transmission through gears, park, reverse, 1st, 2nd, drive, neutral. I pause a little in each gear with the longest pause in drive before leaving it in neutral for the tow.
Blue Ox towing equipment. 5-6000 miles so far.
JayGee
2005 Winnebago Sightseer 29R
Workhorse P32 chassis
accsys
Green Cove Springs, FL
Posted: 07/09/12 05:49am Link  |  Quote  |  Print  |  Notify Moderator
We have towed the Libby in our signature for about 50,000 miles over the last seven years and haven't experienced one bit of trouble with her. She is towed four down of course.
John & Doris
Doris and Robbies Blogs
2007 Tiffin Phaeton QDH 40 w/Cat 7 350
2004 Liberty Renegade 4x4 Toad
Roadmaster Falcon 2 tow bar
Air Force One toad braking system
FMCA F380583, PA, Good Sams
paulcardoza
Southeastern Massachusetts
Posted: 07/09/12 05:50am Link  |  Quote  |  Print  |  Notify Moderator
Hi peaches&cream,
Quick question....... Do you find that with the Miata, you miss having a toad that you can carry stuff around with when you are away? We have our Jeep Wrangler Unlimited set up to tow, but have been toying with the idea of setting up our Miata as well. With the two of us and two dogs, we just cannot imagine dealing with the Miata, only, when away. We do miss the little bugger when traveling though!!!
Paul & Sandra
New Bedford, MA
2003 Monaco Executive M43 DS2
JoeH
Apollo Beach,FL
Posted: 07/09/12 05:52am Link  |  Quote  |  Print  |  Notify Moderator
Two of them....
Geo Tracker, 4 down, no mods needed, weights less than 2200
Rord Ranger, 4 down, installed neutral tow kit, weights about 3600
zmotorsports
Utah
Posted: 07/09/12 05:57am Link  |  Quote  |  Print  |  Notify Moderator
This is what we tow:
2011 JK Unlimited Rubicon.
This is how we generally tow it.
This is how we haul it if we are staying for an extended stay and want to take the Harley as well.
Which will have this in front of the Jeep in the trailer.
2003 Monaco Dynasty/ 26' Haulmark Edge trailer
2011 Jeep Unlimited Rubicon
peaches&cream
Northwest Georgia
Posted: 07/09/12 06:01am Link  |  Quote  |  Print  |  Notify Moderator
paulcardoza wrote:
Hi peaches&cream,
We have never had a problem. We store the brake buddy in one of the MH compartments when we are in a campground and use the trunk of the Miata for groceries when we go to the store. We only have 1 dog, a pug, and he loves riding with the top down. I have often thought about someting bigger but the Miata has met our needs for 5 yrs. of traveling. There is another couple that camps with us often and they also tow a Miata. We were in Farmington, NM parked side by side and everyone coming in commented about 2 Miata's from Ga. parked outside. They draw attention where ever we go.
ets1996
tumwater,wa.
Posted: 07/09/12 06:04am Link  |  Quote  |  Print  |  Notify Moderator
we tow 1993 geo tracker 2 wheel drive 5 speed, steering wheel unlocked, weighs 2200#, although not required all states recently aquired roadmaster brake pro supplemental braking. tows great.
Page of 10
 > Whats your toad
