CA Traveler
The Western States
What's your experience with this app? I'm currently in Humbug Mountain SP in Oregon w/o AT&T 4G service or data service. The app description says it works best with 4G so is it worth $10 for this location?
To be clear I'm asking about usage on the iPhone with ATT and I'm posting this using Verizon data service.
Should I bother driving to a location to download the spp and then attempt to use it back here at the CG?
And yes I'm new to the iPhone, apps and AT&T service.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
djgarcia
Northern, Ca. , USA
What is the actual name of the Dish Pointer for the iPhone?
Dick
djgarcia@earthlink.net
schneid
In the Wind
DishPointer Android is a stand-alone app requiring NO service. It does need your GPS ON to be accurate especially if your location can't be pinpointed by cell towers. I only use it for site survey as I think Android SatelliteFinder is more useful.
If Android has an app, iPhone usually had it first.
schneid
In the Wind
Thought I'd try to help you out but that iTunes is too complicated for me to get around in.
Larry Cohen
Mobile, AL
Check out SatFinder...it works great...your camera becomes a sighting tool...GPS based
2006 Mountain Aire 43
Short haired wife, long haired daschund and 3 sugar gliders are co-pilots, along with Garmin Nuvi 855
05 Honda Pilot with Air Force One supplemental brake
Blue Ox Aventa II towbar
Whirlpool Residential Fridge !!!
CA Traveler
The Western States
The actual name is DishPointer Augmented Reality App.
USARMYCW
TEXAS or somewhere in between
I no longer have a use for it, but from reading all the reviews on iTunes store the "Pro" version is what I would get. The Pro version is $19.99.
It uses the GPS function is why the 3gs and 4 iPhones are needed. You don't need internet or a connection to the cellphone service to use it. You point it at the sky and it shows you where all the sats are.
dbond21201
Jackson, TN
i have the satfinder app. It was only about $4 and no other fees. Has been a huge help to DH.
Dianne & Wilmot Bond
West Tennessee
TechWriter
On The Road
USARMYCW wrote: . . . from reading all the reviews on iTunes store the "Pro" version is what I would get. The Pro version is $19.99.
I 2nd this. I've been using it about a year on an iPhone. It slices, it dices.
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
- Solar -- Solar Power
- Water -- Water Filtration
- Blog -- www.rvSeniorMoments.com
SCVJeff
Santa Clarita, CA.
CA Traveler wrote: The actual name is DishPointer Augmented Reality App. It's actually known as 'DP AR' once installed, and that search will get you there. You're correct that it apparently wants Internet or phone for Location Services to work. I put mine in Airplane Mode, and the app came back to tell me that it couldn't resolve a location even though GPS is on and the app has permissions to access it. I sent a note to the developer to see why that is?
Jeff - WA6EQU
