RV.Net Open Roads Forum: Fifth-Wheels: AC Mystery
 > AC Mystery
okiejoe
Oklahoma City
Posted: 07/10/12 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
Someone please tell me WHY my AC stopped working when on of my batteries went bad, it left me with one battery which because of the dead battery was weak as it was getting drained by the dead one. So AC would not start while I was plugged into 50 amp aervice and then my furnace would also not ignite as well as my water heater. replaced the bad battery and of course my furnace worked fine as well as my water heater but then just for fun tried the AC and low and behold it worked. I had a service tech look at it while in Yellowstone and he said the compressor was bad so just to replace the AC. SO what does the batterys have to do with the AC starting (remember I was plugged into 50 amp service)? also my AC is blowing at 50 degrees, is that good or should it be blowing alittle cooler, unit is a Carrier with remote control and is 8 yrs old and carrier does not make RV AC's anymore. Eager to hear your therory.
AUWing
Slinger, WI
Posted: 07/10/12 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
Low voltage to the t-stat?
From someplace in SE Wisconsin
2011 Silverado 2500 Ext-cab / reg box / D/A
2008 Jayco Eagle 313RKS
2008 Goldwing
Kybiggray
Central City Ky
Posted: 07/10/12 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
X2 on t stat.
RedG
Fort Worth Texas
Posted: 07/10/12 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, the thermostat works off 12 volts as well as the furnace and water heater controls...
You need to check to see if your converter is working.
2005 Newmar Dutch Star 4024 DP 370 Cummins
Towing my 2012 Malibu w/Blue Ox towbar & Patriot brake system
garym114
Bluff Dale, Texas
Posted: 07/10/12 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
12v DC is needed for the thermostat to work, furnace control, water heater control and refer control.
rockhillmanor
On the Road
Posted: 07/11/12 09:49am Link  |  Quote  |  Print  |  Notify Moderator
Took me days chasing the problem of why the air would come on but I'd go back and it was off.
Bad converter, cooking battery......12V is needed for thermostat on A/C and many refrigerators. Thanks to a forum member pointing that our for me solved 'my' problem.
"We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us".
fla-gypsy
North Florida
Posted: 07/11/12 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
X2, your convertor is not working properly and probably killed the battery too which means it will happen again if not addressed soon
okiejoe
Oklahoma City
Posted: 07/11/12 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks I will check into the converter.
okiejoe
Oklahoma City
Posted: 07/12/12 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone, great info, just had the converter replaced at CW today and sure enough it was my problem. Vaction back on, currently in Licoln City, Oregon and loving it. I can always depend on my 5er freinds.
 > AC Mystery
