RV.Net Open Roads Forum: Technology Corner: Satellite hookup to RV?
 > Satellite hookup to RV?
lightkeeper69
Alabama
Posted: 07/15/12 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
When I am in a campground or RV park with cable, I have no problem receiving programs on both TVs in my Jayco travel channel by plugging in the connection to the coax input on the side. However when trying to use my DirecTV receiver I have no reception - even with the power booster switch off.
Any ideas? Thanks.
If I Die While Camping, I'm Already Halfway To Heaven
nalcon
SE Texas
Posted: 07/15/12 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
Satellite usually won't work on the cable connection. Try running coax from satellite dish straight to receiver without any splitters.
Charlie and Sherrie
'99 Fleetwood Southwind Storm 31'
'10 Honda CRV EX-L
FMCA F417071
Eycom
32043
Posted: 07/15/12 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
The signal from the dish needs to have a direct un-impeded path to the receiver. Typically the TV's amplifier (power booster) negates the signal when the coax from the dish is connected to the outside cable connection. There's a simple Satellite Rewire modification to bypass the booster. It works. The alternative would be to fish a separate line through the RV, cabinets etc., whatever... Hope it helps.
* This post was edited 07/15/12 10:03pm by Eycom *
RVn Full-time
goodwin297
Posted: 07/15/12 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
DirecTV techs happened to be in a RV park we were at last week. I have the Winegard Dome and 2 inputs on the side of our 5r. The sat input worked perfect but not the cable input same reasons as stated above. The techs took the by pass off on the inside so now I enjoy my DVR. Our 2nd TV will either use the batwing or park cable fished through the window with a flat cable.
Trudi
Full-Time RVers since 6/16/2012
Our home:
'05 Crossroads Paradise Pointe 33RL
'12 Dodge Ram 2500 6.7 Cummins Diesel Crew Cab
Doggies - Molli, Indi and Louie
Hamster - Buddy
ch-ta
MN
Posted: 07/15/12 10:52pm Link  |  Quote  |  Print  |  Notify Moderator
The dish receiver feeds dc voltage to the LNB on the dish. Any obstructions such as a splitter can block the voltage from getting out to the dish.
2012 Chevrolet Silverado 2500HD CC 4WD LTZ
2013 Keystone Sprinter 266RBS
ADAD437
New Albany,Ind. USA
Posted: 07/16/12 07:27am Link  |  Quote  |  Print  |  Notify Moderator
Your link will not work for me.
James,Gail & Pancho
2005 georgie boy Pursuit
Eycom
32043
Posted: 07/16/12 08:11am Link  |  Quote  |  Print  |  Notify Moderator
Works fine from this end. Try, http://www.flamingsquid.com/images/satellite_rewire.pdf. Good luck.
pulsar
Lewisville, NC
Posted: 07/16/12 08:19am Link  |  Quote  |  Print  |  Notify Moderator
The link is to a pdf file; the link works for me.
Tom
paulcardoza
Southeastern Massachusetts
Posted: 07/16/12 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Assuming your Satellite receiver is in the A/V cabinet where all your other connections are......
Locate the park cable coax, coming in from the outside connector. Connect that cable to the sat-in on your sat-receiver.
With this setup, I can receive SAT when the dish is connected to the park cable input. When I have CG Cable connected, I just leave the SAT receiver OFF and the cable feeds right through as if the sat receiver wasn't there.
Paul & Sandra
New Bedford, MA
2003 Monaco Executive M43 DS2
Clay L
Sioux Falls, South Dakota
Posted: 07/16/12 08:59am Link  |  Quote  |  Print  |  Notify Moderator
There are several ways to do it. Winegard recommends the diagram below.
Making the connections the way Winegard recommends does not require adding any coax connectors to the wall plate.
Note that this assumes your front TV is connected to the coax connector on the front of the wall plate. If yours isn't, there should be a splitter in the line labeled "To second TV" that will send the signal to both the front and rear TVs (if you have two TVs).
What Winegard calls a "power supply" below is the wall plate with the antenna booster switch and LED showing when the amplifier is on.
If you still want to be able to use the external cable in for both cable TV and the external dish just add an A/B switch to switch the incoming coax from the sat receiver "sat input" to the sat receiver "TV input".
One thing not shown in the diagram is using the RCA type connections or the better quality "component" type output or the HDMI (best) output between the sat receiver and the TV.
That will yield a much better picture with no interference from any local channels. You have to select a "video in" with your TV menu instead of using channel 3 (for example).
Some newer satellite receivers don't have a coax output so you may have to use HDMI or component connections.
If you have a video distribution box that will have to be taken into account.
Clay (WA5NMR), Lee (Wife), Katie (cat).
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
