RV.Net Open Roads Forum: Pigtail to utilize both 30 amp and 20 amp plugs
 > Pigtail to utilize both 30 amp and 20 amp plugs
howardwheeler
West, Texas
Posted: 07/16/12 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
At a lot of state park sites they give you standard 30 amp plug plus a 20 amp one. Do they sell a pigtail that will feed 30 amps to one leg of my 50 amp plug and 20 to the other so I could run two ACs?
smkettner
Posted: 07/16/12 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
If the 20a is GFI it will not work. In that case you would need to rewire to power the second air seperately with an isolated circuit.
675 watts solar
howardwheeler
West, Texas
Posted: 07/16/12 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
Where we are the 20 is a gfi. Too bad.
Old-Biscuit
Across the USA
Posted: 07/16/12 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
Haven't seen that kind of adapter.
But I'd bet that most 20A receptacles are wired off of the 30A receptacle vs individual wiring runs from main feeder.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
smkettner
Posted: 07/16/12 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
http://www.progressiveindustries.net/cheater_box.htm
ch-ta
MN
Posted: 07/16/12 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
Usually I see both the 30A and 20A outlets at the power ped. Not sure if there is an adapter that would be safe for you to use though.
2012 Chevrolet Silverado 2500HD CC 4WD LTZ
2013 Keystone Sprinter 266RBS
tandkj
Full timer
Posted: 07/17/12 07:11am Link  |  Quote  |  Print  |  Notify Moderator
The CW in Las Vegas sold them in the past, don't know if they still do or not. Give CW a call.
Tis another fine day to serve in and for the glory of the Corps. Every day is a holiday and every meal a feast.
08 Camelot
07 Ranger Toad
One Golden Retriever at the Rainbow Bridge and a new one traveling with us.
howardwheeler
West, Texas
Posted: 07/17/12 10:37am Link  |  Quote  |  Print  |  Notify Moderator
Any way to defeat the gfi?
BB_TX
McKinney, Texas
Posted: 07/17/12 11:25am Link  |  Quote  |  Print  |  Notify Moderator
Replace it with a non GFI.
Dusty R
Charlotte Michigan 48813
Posted: 07/17/12 11:42am Link  |  Quote  |  Print  |  Notify Moderator
Depending on it's wired, if you had what you are talking about, the prongs on the plug not plugged in yet could be hot after you plug the first one in.
So now what happens after you plug the first one in and get distracted ?
Dusty
