PU-Newbie
Dollard des Ormeaux
We are seasonal campers and have been at the same campground for the last 4 years. We just recently bought a new 31 foot TT and I have so far blown the breaker twice this season. I am aware never to turn anything on other than lights while the A/C is on and did not at the time of the breakers blowing. While they were flipping it back last weekend, I noticed that the breaker was 10 amps. I am concerned more about doing damage to my TT then to their breaker that has blown. Any suggestions or ideas ?
Thanx...
Rich...
2 Parents
2 Kids
2 Mortgages now
09 Santa Fe ("Black Beauty")
2012 Zinger 31SB ("the mobile puppy 3")
2002 Shamrock 23
" Flexible people don't get bent out of shape. "
othertonka
Stockton, CA
ask the manager about the ten amp breaker and ask him if it is a mistake. Are you hookrd up to the 30 amp outlet on the pedestal? Ask him to have it checked out. If you are hooked up to a 30 amp outlet it should have 30 AMP Breaker.
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
2oldman
Wilson Creek WA
The CG breaker is 10a? Yikes.
ch-ta
MN
othertonka wrote: ask the manager about the ten amp breaker and ask him if it is a mistake. Are you hookrd up to the 30 amp outlet on the pedestal? Ask him to have it checked out. If you are hooked up to a 30 amp outlet it should have 30 AMP Breaker.
I agree, 10A is not enough to run AC.
2012 Chevrolet Silverado 2500HD CC 4WD LTZ
2013 Keystone Sprinter 266RBS
smkettner
Do you have an electric water heater element? Random 12 amps right there. Air is ~12 amps, converter 2 amps, fridge on electric 3 amps.... 29 amps, right on the edge.
675 watts solar
hmknightnc
Wilmington, NC
2oldman wrote: The CG breaker is 10a? Yikes.
x2
JJBIRISH
Butler, PA, USA
A quick trip to the office… 10A is crazy…
Where I am I own my breaker and everything my side of it… the power company owns the meter and everything to it… the camp cround ownes the pedistal
Love my mass produced, entry level, built by Lazy American Workers, Hornet
Drbolasky
Allentown, PA
10 amps?? Probably installed by Edison himself.
CG needs to upgrade.
Doug, Linda, Audrey (USN) & Andrew
08 Sequoia SR-5, 5.7 L, 6 sp. Auto, 4.30 Rear, 2000 Coachmen Futura 2790TB Bunkhouse, Dexter E-Z Flex Suspension, Reese W.D. Hitch/Dual Cam Sway Control, Prodigy Brake Controller, McKesh Mirrors
HappyTrails2U2
Tennessee is home but being held hostage in GA.
PU-Newbie wrote: I am aware never to turn anything on other than lights while the A/C is on and did not at the time of the breakers blowing.
If you have a new trailer that shouldn't be a problem running other things in the trailer while the A\C is running. We run the A/C and the microwave along with the TV and refrigerator at the same time and it doesn't trip the breaker. Except of course as you've found out you couldn't do it with a 10 amp breaker at the meter.
2010 Rockwood Signature Ultra Lite 8315BSS
2003 Chevy Silverado 1/2 Ton Extended Cab
skipnchar
Topeka or somewhere else
Damages occur from low VOLTAGE not low amps. Low amps results in tripped breakers. Think of "volts" as the drink you're drinking and think of "amps" as the size of the glass you're drinking from. The glass size doesn't change the drink inside to poison.
If your new trailer has wheels, I'd be using them and find a campground that can provide the 30 amps your trailer needs so you can use everything in it as intended.
Good luck / Skip
