RV.Net Open Roads Forum: Toy Haulers: Need Tire Pressure Help!
Search only in Toy Haulers
 > Need Tire Pressure Help!
PitkinTH
Kansas
Posted: 07/20/12 07:11am Link  |  Print  |  Notify Moderator
I am trying to figure out the correct tire pressure. We have 1/2 truck with BF Goodrich P275/65R18 tires. The trucks door panel says 30psi Front and 33psi Rear. Max tire pressure on sidewall of tire says 44psi. We are pulling a 19 foot Toy Hauler with a weight distribution hitch. The Toy Hauler tires show max tire pressure of 50psi. What should I run for tire pressure for the truck and Toy Hauler? Thanks
Dick_B
Palos Heights, IL USA
Posted: 07/20/12 07:47am Link  |  Print  |  Notify Moderator
There has been enough discussion on tire pressures to make War and Peace seem like a handbook!
You'll get lots of answers but I would load up all tires to their max cold pressure when towing.
When not towing drop the truck pressure to the door pressures.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
allcool
sFL Glamis PHX
I'd run max cold tire pressure on the 1/2 Ton truck, and look on the TH sticker for recommended th tire pressure, its probably max tire pressure also.
The truck owners manual will probably have towing tire pressure recommendations also.
You could always weight your rig and compare tire load,axle, max tongue weight capacities, to actual tongue weight, and real gvw. Then adjust air pressure as needed.
To get max tire load capacities, max inflation pressure is needed.
My guess is, with a 1/2 ton truck and a loaded 19' TH, you will be close to max load if not over on all, especially tongue weight once truck is loaded with passengers, fuel,and gear.
This would at least require max tire pressure all around.
jmo
2007 WW FSW3200
RZRS k&t Turbo
2 LT500
1 Lt500 hybrid
River&Sand
San Diego, CA USA!!!
Posted: 07/20/12 08:44am Link  |  Print  |  Notify Moderator
Well you are running P rated tires, I would use max tire pressure on sidewall for towing and drop back to door sticker pressures when not towing. The P rated tire is a car tire not a LT which is a truck tire. The sidewall will flex more on a P rated tire than a LT. So that means you want to take out the flex = heat, the stiffer you make the tire the less flex which means cooler running. This good for towing but not driveabilty when not, i.e, rough ride unloaded. If you plan on towing alot I would switch to an LT tire.
River&Sand
05 Chev Ext.Cab K3500, Dmax/Alli, DRW, Reese Signature 18k, HappiJac, Jordan 2020
05 Lance 920 Truck Camper
06 Weekend Warrior LE3305, 5th Airborne, Dexter E-Z Flex
01 HighJumper SandSprite 3 Dune Buggy
nayther
Burbank, CA
Posted: 07/20/12 08:50am Link  |  Print  |  Notify Moderator
max per the tire sidewall markings on all 8 tires.
DIRT BIKES RULE
'12 Duramax CC short bed
'06 3005 Rage'n Falcon
HuckleberryHunter
Issaquah, WA
Posted: 07/20/12 08:51am Link  |  Print  |  Notify Moderator
x2
I have since switched to LT tires from my stock P-rated tires, but previously I'd run max (sidewall info) when towing and a little lower when not carrying a load. I still do the same with my LTs. In addtion to ride comfort, when not carrying a load, if you run your tires at max air pressure all the time, you can get uneven tire wear (center will wear faster). Probably not as much an issue with P tires as LT.
CapriRacer
Somewhere in the US
Posted: 07/20/12 09:39am Link  |  Print  |  Notify Moderator
Dissenting opinion here:
If you are towing within the capability of the truck, then the pressures listed on the vehicle tire placard are part of that capability. It would probably be beneficial to add a few more psi - 3 to 5 psi - but adding 50% more should sound wrong - and it is.
CapriRacer
Visit my web site: www.BarrysTireTech.com
johntank
Oxford, Ms 38655 USA
Posted: 07/20/12 09:59am Link  |  Print  |  Notify Moderator
I like most of the others will say run all tires at max cold inflation presssure on tire side wall for truck & trailer.
Doughboy12
Minnesota
Posted: 07/20/12 10:55am Link  |  Print  |  Notify Moderator
Might be true IF the stock tires are still on the truck.
I always go by the tire for tire information.
If there was a sticker on your tires that said use 50w oil would you put that in the engine???
Francesca Knowles
Port Hadlock, Washington
Posted: 07/20/12 11:47am Link  |  Print  |  Notify Moderator
safercar.gov.: Tires/ Proper Inflation wrote:
5)What about the psi number listed on the side of my tires? Should I fill my tires to that pressure?
Tires are manufactured for many different vehicle makes and models of vehicles. And the psi number on the side of a tire only reflects the “maximum permissible” inflation pressure for that tire — not necessarily the correct psi for your vehicle. When filling your tires, always follow your vehicle manufacturer’s psi recommendations. You’ll find this psi number on your vehicle’s tire information label, as well as in your vehicle owner’s manual.
Above is from: Safercar.gov/ Tires
BF Goodrich wrote:
Your tires should have the recommended pressure listed by your vehicle's manufacturer. This information can be found in the vehicle owner's manual and often on a placard located in the vehicle's door jamb, inside the fuel hatch, or on the glove compartment door.
Above is from BF Goodrich help page
Bridgestone/Firestone Tires wrote:
Look for the manufacturer’s recommended tire pressure listed on the sticker usually located on the driver’s-side door edge or door jamb area.
Above is from Bridgestone/Firestone tire maintenance
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
