RV.Net Open Roads Forum: Tech Issues: solar panel and controler, will this work?
 > solar panel and controler, will this work?
Page of 8
j.p.f.
ga.
Posted: 07/21/12 06:57am Link  |  Quote  |  Print  |  Notify Moderator
is this a mppt controler?
xantrex
and or will it work with two of these.
solar panel
hypoxia
Arizona
Posted: 07/21/12 07:06am Link  |  Quote  |  Print  |  Notify Moderator
xantrex
solar panel
No and No
You need an MPPT controller for that voltage for a 12 volt camper. I like Morningstar controllers, I have a Sunsaver MPPT on my 5th wheel camper with 240 Watts of solar & a 60 Amp Tristar MPPT on my motorhome with 760 watts of solar. The Morningstar controllers have a large heat sink and do not require a fan for cooling like some other controllers. Those panels are fine.
Jim
2003 Fleetwood Revolution 40C
KD4UPL
Swoope, VA
Posted: 07/21/12 07:16am Link  |  Quote  |  Print  |  Notify Moderator
The only MPPT units Xantrex makes are the XW-MPPT60-150 and the XW-MPPT80-600. Neither are very well suited for an RV. I would look at Blue Sky or Morningstar.
Fire Instructor
Upstate (Albany) NY Area
Posted: 07/21/12 08:40am Link  |  Quote  |  Print  |  Notify Moderator
Love my Rogue controller / charger. Easy to install, good display, works well, GREAT company to work with.
Fire Instructor
2004 Dodge 1500 4dr 4x4
2009 Rockwood 2607
300 Watts of SunTech Solar Panels
Rogue MPT-3024 Controller & Xantrex PW2000 Inverter
"If everyone is thinking alike, then someone isn't thinking!" General George S. Patton
pianotuna
Regina, SK, Canada
Posted: 07/21/12 11:35am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Nice panels.
I'd go with two and a Rogue Controller.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
2oldman
Winchester WA
Posted: 07/21/12 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
According to the specs shown on the linked page, no, it's a PWM. As for whether it will accept a 24v nominal panel (as you also linked), I don't know.
More research is necessary.
smkettner
Posted: 07/21/12 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
Nice panels.
+1
675 watts solar
hypoxia
Arizona
Posted: 07/21/12 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
I've been out in the sun all day so my brain may be fried, however... The Rogue controller is 30 amp max. & those 2 panels will put the controller right at the amp limit won't they? That in itself is OK, it just doesn't allow you to ever add any more panel. Just a thought for the future.
2oldman
Winchester WA
Posted: 07/21/12 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
There's only one "rogue" controller?
mena661
Posted: 07/21/12 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, only one.
Trojan L16 6V's 740 Amp-hours
Page of 8
