RV.Net Open Roads Forum: Forum Technical Support: Trouble Posting
Search only in Forum Technical Support
Open Roads Forum  >  Forum Technical Support
 > Trouble Posting
rhqjr
Mississippi
Posted: 07/21/12 10:56am Link  |  Quote  |  Print  |  Notify Moderator
I received the below message while trying to post on a forum. The message i was trying to post was very lengthy.
Any suggestions.
The following problems were encountered while processing your request:
> Your message contains invalid formatting. Please use the toolbar provided to ensure proper formatting.
sch911
Rochester Hills, MI
Posted: 07/21/12 11:09am Link  |  Quote  |  Print  |  Notify Moderator
Did your post have special characters such as brackets, backslashes or paratheses in it?
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
2oldman
Winchester WA
Posted: 07/21/12 11:28am Link  |  Quote  |  Print  |  Notify Moderator
You likely have an unmatched bracket. I can't even type the bracket character in quotes as I get the same message.
pulsar
Lewisville, NC
Posted: 07/21/12 11:33am Link  |  Quote  |  Print  |  Notify Moderator
An "invalid formatting" error is always because of the use of square brackets.
So as not to require much overhead, the software currently is doing a rudimentary check and doesn't know what the actual error is.
In essence, the software is counting brackets. Since this post has [two][sets] of open and close brackets, it passes the syntax check. An odd number of pairs would fail. Errors occur when posters use brackets instead of parentheses for parenthetical comments; using an open format tag and forgetting to close (for example, start bold without an end bold); some times it is just an extra bracket, (for example using two open brackets instead of one). The two biggest causes I see are improper editing of quotes (removing one tag and not the other) and using brackets instead of parentheses.
This simple check was instituted because these format errors were hanging the servers as the display engine tried to resolve the errors when it formatted a page.
Tom
 > Trouble Posting
