RV.Net Open Roads Forum: Tornado flush lifespan
jamnw
Decatur, TN
Posted: 07/21/12 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
I installed a tornado in my black tank 5 years ago. It has worked perfectly until this summer.
Today I took it out and installed a new one. The old one will not spin. I can spin it by hand, but it has some resistance.
Has anyone else had this kind of problem? What can I do to prevent further problems?
Thanks
Jamie
MARRIED WITH 2 BOYS: AGES 9 AND 7 years!
2000 F250 PSD/CREW CAB
2006 Smokey TT 28ft
USN Veteran
AT&T Repairman
tenbear
Northern Vermont, USA
Posted: 07/21/12 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced mine after about 3 years, but it was because the plastic thing that holds the hose in place broke. The new one has a metal thing. It has been in use for 3-4 years and I think it may not be spinning (different noise) but it is still keeping the tank flushed out so I haven't taken it out.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
ronfisherman
SE Michigan
Posted: 07/22/12 03:56am Link  |  Quote  |  Print  |  Notify Moderator
I have replaced one of my tornado's twice. One time because the hose connections was made out of plastic. Next time because I did not run antifreeze through the connection. Does not take much water freezing to breakup the mechanism.
Kodiak Chassis Class C Forum
