RV.Net Open Roads Forum: Can I and Should I tow a Park Model one time short distance?
Search only in Towing
Open Roads Forum  >  Towing
 > Can I and Should I tow a Park Model one time short distance?
rolnhome
Casa Grande, Az
Posted: 07/22/12 12:45am Link  |  Print  |  Notify Moderator
Overwidth big problem. Overweight big problem.
Now the plusses? ?????
We're in Arizona
bankcardrep1
Asheville, nc
Posted: 07/22/12 05:58am Link  |  Print  |  Notify Moderator
Thanks for the input. I forgot about width. I am getting the specs on it now. I had considered liability.
Also, towing here is not flat. This one is in Spartanburg SC going to Culowhee NC. Several steep long grades involved.
sunkatcher
Fulltimer
Posted: 07/22/12 06:08am Link  |  Print  |  Notify Moderator
Bet ya a dime she has no brakes. That is one of the first thinks that go on a park medel when they sit for a long time.
masa4u.com
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/22/12 08:59am Link  |  Print  |  Notify Moderator
I would call a commercial mobile home mover to come out and pull it. They'll come with a class 8 tractor that has more than enough hitch weight capacity and pulling power to do the job and already know the ins and outs of towing an older park model that has been sitting for years, plus they have the insurance to cover anything that may go wrong. This is not a job for a private guy with a 3/4-ton pickup.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
NC Hauler
Asheville NC
Posted: 07/22/12 09:12am Link  |  Print  |  Notify Moderator
bankcardrep1 wrote:
I have a 06 Chevy Duramax, 2500.
Someone asked me to tow their park model to a permanent spot.
Maybe 75 miles of intersate.
40' Trailer.
I am accustomed to pulling 28' TT and have had experince with longer.
Not concerned about my skilss as much as the truck ability to tow safely and not damage truck.
Your evidently somewhere in my vicinity....ie, the mountains....I "might" try it with my 1 ton Dodge Dually, BUT would have to see it, walk around in it and look at the tires and check air pressure, BUT, would I try it with a 3/4 ton.....nope....not anywhere around here in the Asheville area...not in the mountains....
on edit; didn't see "page 2"... Spartanburg SC going to Culowhee NC....STILL wouldn't do it with 3/4 ton truck....too much trailer and several steep grades...."wouldn't be prudent"
Jim & Kathy
2013 Dodge 3500DRW Longhorn 4X4/CC/LB/Aisin tranny/4:10/Cummins: 385HP/850TQ
06 HR Presidential Suite 37RLQ/ 4 slide/ dual pane windows/Winegard SK3005 Satellite/Splendide XC2100 W/D
Boxers;Buddy& Sheba II
USAF 71-75 Nam Vet
WVU fan
Jack_Diane_Freedom
Milton Ontario Canada
Posted: 07/22/12 09:27am Link  |  Print  |  Notify Moderator
Does it even have trailer brakes?
samsontdog
Oregon, Wash Coast summer, Yuma Az winter
Posted: 07/22/12 09:29am Link  |  Print  |  Notify Moderator
I have a 3/4 ton Ford p?up and I moved a Park Model one block for a Guy who bought it from me. No way would I move a Park Model 75 miles !!!!!!
samsontdog
Allworth
Orlando, FL
Posted: 07/22/12 03:52pm Link  |  Print  |  Notify Moderator
No!
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Trucks Don't Have Sparkplugs"
Huntindog
phoenix arizona USA
Posted: 07/22/12 05:40pm Link  |  Print  |  Notify Moderator
I think there is some confusion here.
A park model is simply a large TT usually around 40', that has no provisions for dry camping. They are around 8' wide. give or take a few inches. The 12' wide units that some are describing are mobile homes....A totally different class.
Since a "park model" TT lacks some of the equiptment that a standard TT has, it often will weigh less than you would think...BY no means are they light, but around 10K is not unusual. That would be within the Dmax's capabilities
If this is a used unit, is it empty? or full of belongings? This will likely be the deciding factor in whether you can/should pull it or not.
Of course all the running gear needs to be up to snuff. Brakes, tires, hitch etc. If it has been parked awhile all these things may need work.
Huntindog
2010 Palomino Sabre 30BHDS
TWO bathrooms...No waiting!
MICHELIN XPS RIBS LRE
2011 Silverado Big Dually 3500 4x4 CC D/A
EQUALIZER Hitch
100% BOONDOCKING
Check out Rusty and her pups at www.bluecollarbrittanys.com
retired-tech
flint mi
Posted: 07/22/12 06:29pm Link  |  Print  |  Notify Moderator
X2 a park model is not going to be 12 feet wide. make sure that your friend has insurance to cover it while towing make sure the brakes work and drive it appropriatly.
2000 K3500 CCLB DRW 6.5 TURBO
2009 Cougar 320 SRX
2007 atlas 24 auto hauler
1987 GMC origional low miles
