RV.Net Open Roads Forum: Toy Haulers: Weekend warrior brake problems
Search only in Toy Haulers
 > Weekend warrior brake problems
Alldaysports
North Dallas
Posted: 07/22/12 06:50am Link  |  Quote  |  Print  |  Notify Moderator
When I hook up my WW toy hauler to my f250 my WW sometimes shows "no trailer connected". it happens more than 50% of the time and I also notice that I have no turn or brake lights on my right side of my trailer.
To add to my WW issues, when I turn a particular light on my interior light panel mytrucks reverse lights come on.
Has anyone experienced these issues? Any help is appreciated.
Thanks.
Cp
allcool
sFL Glamis PHX
Posted: 07/22/12 08:01am Link  |  Quote  |  Print  |  Notify Moderator
I'd start by checking the trailer plug and truck plug socket for burnt/melted/bad connections. And/Or the trailer harness for a short/open.
2007 WW FSW3200
RZRS k&t Turbo
2 LT500
1 Lt500 hybrid
Alldaysports
North Dallas
Posted: 07/22/12 08:10am Link  |  Quote  |  Print  |  Notify Moderator
What do you mean by short/open? Please excuse my rookie questions.
allcool
sFL Glamis PHX
Posted: 07/22/12 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Just look over the Harness for cuts(possible open)or spots that are worn thru allowing 2 wires to touch(short).
I'd pay particular attention to the Harness plug looking in it carefully for melted bad connectors.
Just some easy stuff to check first, and a common area for problems.
carringb
Corvallis, OR
Posted: 07/22/12 08:31am Link  |  Quote  |  Print  |  Notify Moderator
WW's have terrible brake wiring. Best option is to run all new from the connector back.
The reverse lights are also connected to the rear patio lights. There is no relay though, so if your truck doesn't have a relay (Fords do, other's don't) the patio switch will backfeed to the truck.
Bryan
2000 Ford E350 DRW Wagon (14-pass all captains chairs)
V10 w/ Banks PowerPack, Diablo Predator, 4.56 LS, ~350,000 miles
New Desert Fox in the works!
Alldaysports
North Dallas
Posted: 07/22/12 09:14am Link  |  Quote  |  Print  |  Notify Moderator
The patio light make sense but I have a ford f250.
dedmiston
Valencia
Posted: 07/22/12 09:56am Link  |  Quote  |  Print  |  Notify Moderator
It could be a dirty connection. Try some WD-40 or some LUBE.
2004.5 Dodge 2500 Diesel • 2005 Weekend Warrior FS2600 • Hooligan #3
Toys:
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
  • 06 Yamaha TT-R90E
The Edmistons - Our Gallery
Never forget 9-11-01 Check out our blogs @ blog.rv.net
strudeau
Livermore California
Posted: 07/22/12 09:57am Link  |  Quote  |  Print  |  Notify Moderator
My 2006 CL4005 had all of these issues, and at the time I had a 2005 Ford F-350.. I never could correct the issue win the trucks reverse lights coming on, and it didn't happen all the time. The trailer brake controller flashing ended up being grease on one of the brake magnets that shorted out the connection. The rear lights/turn signal was a frayed wire that had been pinched when the suspension ran into the wire bundle that was never attached correctly.
Alldaysports
North Dallas
Posted: 07/22/12 10:43am Link  |  Quote  |  Print  |  Notify Moderator
I just crawled under and inspected all wires were good to go. I inspected the rubber grommets on the axle that the wires were run through and those were fine as well.
I also confirmed that all of my trailer lights are working except left blinker and my truck 2009 f250 sees no trailer attached. Therefore I cannot utilize my trailer brakes or controller (stock controller). Could I have grease on the magnets as mentioned above and what do I need to do to check that?
Thanks guys.
BobWanderer
Perris,Calif,USA
Posted: 07/22/12 10:57am Link  |  Quote  |  Print  |  Notify Moderator
Been there, done that
Common problem no matter what brand TV or TH.
2008 GMC 2500HD 4X4 DMax CC LB
2004 Thor Wanderer Wagon 247WTB
2006 TE450 Husky
2007 Rhino Sport Edition
