ilvtravln
Calif.
We have an 09 Bighorn, it has an electric awning. When I go to put it out the fabric unfurls but not the arms until I pull on one of them. When the awning is open the arms are not perpendicular to the coach. The fabric shifts to one side at least 6 inches. When I go to wind the awning up the fabric shifts back to center but one of the arms seriously twists out of shape, I have to knock it staight. The awning has never been in a severe wind, we have always taken good care of it. I would like to fix it but don't know where to start? Any ideas, Thanks
Art
CANAMKID
SAINT CLOUD,MN.
What model & year do you have?
trickyvic3
Raymond NH.
Sounds like it needs some oil on all the pivot points. I had a similar problem with ours sticking and very slow. I oil it a few times per season now, and it's working just fine.
ilvtravln
Calif.
CANAMKID wrote: What model & year do you have?
Can find a brand or model name but will look again.
JKrussow
Alabama
Does your awning have the two gas springs on it (one on each arm)? Those springs may have lost their pressure and are causing the binding. I believe they are used to aid in pushing the arms out and away from the coach.
John & Rana
Toby "da bear" RIP 12/28/12
Bandit, Kato & Punkin
2004 GMC Sierra 3500 D/A DRW CC, Banks IQ w/Econominder, Speedbrake & CAI, Curt Q5 20K
2011 Heartland Big Country 3650RL
kakampers
Fulltimer
On a Bighorn it's most likely an A&E awning. Ours binds sometimes too... I just bring it back in an then put it out again...usually solves the problem.
2013 Heartland Landmark Key Largo with Mor Ryde IS and disc brakes
2011 Chevy Silverado 3500 DRW Crew Cab Duramax Diesel
ilvtravln
Calif.
trickyvic3 wrote: Sounds like it needs some oil on all the pivot points. I had a similar problem with ours sticking and very slow. I oil it a few times per season now, and it's working just fine.
Will try this, Thanks
ilvtravln
Calif.
kakampers wrote: On a Bighorn it's most likely an A&E awning. Ours binds sometimes too... I just bring it back in an then put it out again...usually solves the problem.
Yes, it is an A&E awning, Thanks
Mile High
Denver, CO
I have a Carefree - but still have a similar issue sometimes. Mine is usually after a wind and the fabric actually slips down the roller track and little and when it winds up the arms are misaligned and wont close all the way.
I've been able to fix mine so far by just jumping on the tailgate of the truck to gain height and giving the fabric a tug to slide it back into place on the roller.
Hope it helps, sorry I don't have any experience with the A&E.
edited 07/23/12 07:43pm by Mile High *
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
fla-gypsy
North Florida
Not uncommon, a lot of things can get them out of whack. Push them straight and lubricate the entire assembly at every joint and tighten every fastener holding it to the RV and at the joints and you may make it better.
