RV.Net Open Roads Forum: Truck Campers: Let there be music!
 > Let there be music!
Boatycall
Tacoma, WA
Posted: 07/23/12 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
Had two projects this weekend, and one was to put in a Kicker 8" subwoofer and Fosgate 500 watt amp. I had replaced the deck with a Kenwood touchscreen DVD a couple weeks ago. New roof speakers are already on order, and I'm trying to decide what to replace the outside speakers with.
I custom made a ported enclosure for the sub to fit perfectly under the dinette. I was originally just going to take the door off, but it sounded surprisingly good with the door closed, and just a bit better with it open, so I left it on for ascetics.
Amp went into the pump/tank/plumbing access area because it seemed the most logical. High amperage power wires from the converter, good access to fine tune the amp, and the space wasn't really used for anything else.
01 F350 DRW 4x4,Torklifts,SuperHitch,F550 Rear Suspension,Roadmaster ANTI-Sway Bar,Rancho 9000s
2012 AF 1150-4 Trojans,1.5kw Inverter,32" LCD,19" LCD,Basboard heat,Dish Tailgator,Ice maker,3 awnings,80a charge circuit,Polk Audio/Kenwood/Kicker sound system
Oasisbob
Portland Oregon 97266
Posted: 07/23/12 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
Really? Are you hearing impaired? You will be. Neighbors will be impressed. But here I am being a crotchity judgmental old geez. You probley are a nascar camper. Sorry, it's just that recently I was required to listen to my neighbor's music without escape.
* This post was edited 07/23/12 09:21pm by Oasisbob *
Oasis Bob
Wonderful wife & 4 Really Fun kids
2008 KIA Sedona 3.8L 24 valve V-6
2001 Bantam Trail Lite B-19
HAPPY TRAILS
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/23/12 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
Does that door vibrate when you have the sub turned up?
I would probably just take the door off and put a heavy duty steel waffle grille over the speaker, so no feet end up going through the cone....
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
Boatycall
Tacoma, WA
Posted: 07/23/12 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
Surprisingly it doesn't at all. But it is only an 8" sub.
And to OasisBob... Where I camp, there are no neighbors. And you especially couldn't get there in a Kia pulling a trailer!
danager
Edmonton Alberta
Posted: 07/23/12 09:57pm Link  |  Quote  |  Print  |  Notify Moderator
Seeing the amp under the water lines makes me a bit nervous! Install looks good. Did you install a switch inline with the remote turn on lead, so you can turn the amp on/off when you want? Even at low/moderate volume, those amps kill batteries kinda quickly.
Amazing how the box volume requirements drop when you use a vented enclosure, needs less power as well.
RZAR66
San Diego
Posted: 07/23/12 10:03pm Link  |  Quote  |  Print  |  Notify Moderator
Love it
2011 Ford F-350 4x4 Regular Cab 6.2
2012 Lance 850
DiscoChicken
Lawrenceville, GA
Posted: 07/23/12 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
Nice. I'll be using bazooka powered tubes for my system.
Adventurer/Ford
Joners
Idaho Falls, Idaho
Posted: 07/23/12 11:26pm Link  |  Quote  |  Print  |  Notify Moderator
I'm relieved to hear that you "camp" where there "are no neighbors". You must camp in a very desolate and lonely place...no wildlife other than yourself. Or, if there are other wildlife where you "camp", then you must somehow disregard their presence with your mantra of "Let there be music!". But hey!
1996 Chevy K1500 4X4 Short Box, 5.7L Vortec, E rated tires, Lance Model 820 with Cabover Struts, Firestone Ride-Rite Air Bags, KYB MonoMax Shocks, Torklift Stable Loads, Happijac Truck Camper Tiedowns and Turnbuckles, Honda Eu2000i Inverter/Generator.
iwon415
Northern California
Posted: 07/23/12 11:33pm Link  |  Quote  |  Print  |  Notify Moderator
I never knew you were "that guy"...
FreeLanceing
Grand Haven Mi
Posted: 07/24/12 05:53am Link  |  Quote  |  Print  |  Notify Moderator
How about a nice pair of quality head phones? Seems to me an amp powered sub woofers and camping are not a good mix. I have sat in a very remote tree stand and enjoyed the distant boom boom boom of some audio nut. The local deer were not impressed either. Sound is one of those things we have to use personal restaint so as not to impose on our fellow man. I would compare a camper with an obnixious sound system to a camper running around naked. One offends the ears the other offends the eyes.
