dianna119
Clovis, CA, USA
OK folks - you all have soo many nice pictures of your remodel. We have a 2002 Journey 32DL. No luck in selling, just wanted a little longer. We will keep and all I plan to do is upgrade and get rid of the brassy look. Ordered satin nickel 12V light to replace and new cabinet hardware. My sticker shock is the wood floors! To not even go under the slides, just from the front door thru small galley area and in hall (stopping at bath and bedroom doors) $2,500.00. I don't get it. Is it labor. I've installed wood, tile in my own home by myself so I have a working understanding of how it goes down. I'm venting, sorry!! Also want to upgrade the TV's but that's where we are electronically challenged. Haven't gotten prices for that yet, but I better put on my wading boots I think.
DiAnna & Jeff
02 Journey 32'
Actively traveling to dog shows with my daughter to show Australian Shepherds, www.sierraroseaussies.com
routeforty
ohio
We put a laminate down in our travel trailer. Just laid it over the linolieum. If you have even 'moderate' carpentry skills you can DIY. We were in Home Depot and they had a clearance on wood floor laminate, can't really remember the price, I'm thinking around 59-69 cents a foot. Used a table saw and a jig saw. Everything just snaps together. If you goof up on a piece, take it back out and try another one. Now we didn't have a slide out to work around, don't know what's involved there, but I'm sure someone will post soon who has done it. Total cost, I'm guessing was under $100. Gary
'05 chevy 3500, duramax, allison, '00 Coachmen Futura 2790 TT, 35th anniversary edition, 05 lance 1130-stable lift
the bear II
Torrance CA.
Someone is trying to rip you off.
We had a bedroom done in our home with true hardwood flooring installed and it was only $2500 for a 10' X 10" room.
The laminate wood flooring is easy to do it yourself.
ArchHoagland
Clovis, CA, USA
Morrison's RV
Dianna have you checked with these people?
They are just south of us, about 20 minutes, and I've had them do several jobs for me.
I am pleased with their work and prices.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Nothing is either good or bad, but thinking makes it so.
mobilefleet
on the road
laminate is a bad idea in any rv......chips too easily and once you have a spill or plumbing leak of any kind you'll be pulling up the whole floor because it will warp. I'd do vinyl planks that lowes sells. 99 cents for a square foot and is thin enough to go up under or fit snugly against the walls and cabinets. I just did a trailer and didn't even have to use shoe molding since it fit well. if you have vinyl floor under carpeting already, you are one step ahead since that can serve as your underlayment. Peel and stick the planks after wiping off floor with alcohol to remove dirt. I will post some pics of my floor later
carpetguy2
N.IL
If you buy a cheap laminate it will chip eventually.There are some nice laminate out there.I have installed every floor possible.
Any flooring will have its good and bad .
I have laminate in my TT not one issue.Also did my Dads MH . No issues.
2007 chevy 3500 ltz CC LB Duramax
2010 Sandpiper 345 RET
2011 Harley Ultra limited
20 ft Searay 190 Seville
dianna119
Clovis, CA, USA
ArchHoagland, I do not like to speak ill of people who provide services. Your suggested person was my 2,500 quote. Too bad cause he really sounded like he knew what he was talking about. Maybe I can take the coach to him to show him the small amount of square footage. We also can take the furniture, sofa, etc out ourselves and put it back down upon completion. Had a quote from 1/2 that amount from RV Outlet over on 99 but I do not feel warm and fuzzy about them.
D.E.Bishop
Eagle Rock, CA
I'm not too up on installing laminate or other engineered flooring but does an RV shop have to install it? If you prep the area I would think a flooring installer would do it cheaper, after all, they are pros and use to doing it and should do it faster and neater than an RV shop. I know the DW wouldn't allow it in the MoHo but we are redoing a lot of the house including new flooring throughout and my office is getting some engineered flooring by Homelegend and it's pretty easy to install.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
1990 Bounder 27D
1995 Suzuki Sidekick 4X4
Stowmaster 5000
mike brez
milford ct
carpetguy2 wrote: If you buy a cheap laminate it will chip eventually.There are some nice laminate out there.I have installed every floor possible.
A little off topic but that over hang on your TT looks like 30 feet. Is that a 80 foot TT.
1994 Pace Arrow 33L,454,P30
2oo4 ground up ridgid chopper 120rwhp
http://community.webshots.com/user/oneHD
ArchHoagland
Clovis, CA, USA
Dianna....keep us updated on this.
I'd be curious to know who has the best price and the best service.
I know Morrison's knows what they are doing, however at twice the price of a competitor it seems steep.
