RV.Net Open Roads Forum: Tow Vehicles: Air Bags
Search only in Tow Vehicles
 > Air Bags
Page of 5
joendeb92
Central Ohio
Posted: 07/24/12 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
We got 4 air bags on the suspension and 2 on the cab, truck rides like a caddy.
joendeb92
Central Ohio
Posted: 07/24/12 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Pipewelder
Posted: 07/24/12 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
I have Pac-Brake airbags, Top of the line IMO! Love em!!!
PikeRoadWarrior
Pike Road, Alabama
Posted: 07/24/12 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
If your truck sits relatively level to begin with, is there any benefit to air bags? My truck doesn't need much (any) help with saggy butt, so I wonder what air bags could really contribute in my situation. Will they help the ride of my truck?
2004.5 Dodge 2500 Cummins 4x4
2009 Sabre 31BHDS
nremtp143
Georgia
Posted: 07/24/12 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
Yes I have air bags and will have them on any truck from now on that I tow heavy with.
2012 Sandpiper 365SAQ, Goodyear G614s, TST TPMS
2010 F350 DRW 6.4L 4x4, Edge CTS, B&W Companion, Viair 10007 air system, Firestone Ride-Rites,Flo-Pro cold air pipe
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
wfreeth
Guelph, Ontario
Posted: 07/24/12 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
I've got the Firestone Ride-Rites on my truck. I usually have between 20-30 psi in them. Funny thing was I when to install them and the upper brackets were already there.
2006 Dodge Ram Megacab Laramie 4X4 Hemi
2004 Four Winds Classic 28BH-M5
Pullrite Superglide 2700/Firestone Ride-Rites
Drive a Hybrid, I need your gas!
rhagfo
Portland, OR
Posted: 07/24/12 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
transamz9 wrote:
The rear of my truck is nothing but air. No steel springs at all. I love them and will buy again.
This sounds interesting, what package?
Thinking about bags, just to smooth out the bad spots in the road (HY26 to Oregon coast). I don't have a need to level.
Russ & Paula
The Beagles Hedwig and Precious.
Portland, OR.
2005 Copper Canyon 293 FWSLS
2001 Dodge 2500 4X4, 5.9 Cummins 5 speed, 3.55 gears, Pacbrake, Power Puck, 258K
greyhd
Oak Hills, CA
Posted: 07/24/12 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
My last 3500 dually had over 200k miles with lots of towing. I added airbags to help as my 5vr has a very high pin weight. They really helped out since the suspension had some miles on it. I had in cab controls which made it really nice to fine tune going down the road. Also it was a huge help when hitching to the trailers, as I could just "bag up" and connect if the trailer was a little high. Even worked getting under the ball of a tag trailer as I'd get about 2-3.5" of lift. Once connected, I'd lower the bag pressure to the appropriate psi.
On my newer dually I've installed bags but have yet to plumb the on board air. The truck doesn't need the help. Right now I just want to use them to assist in hitching.
slarsen
Indiana
Posted: 07/24/12 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
Had Firestone air bags on my 2006 F250, and one of the first things I did with my 2012 was to put air bags on it.
But they are for leveling the truck when hitching my 11K pound 5th wheel. If I never hauled more than a couple sheets of plywood or softener salt, I wouldn't feel any need for them. I don't personally see them as helping the ride when the truck is empty . . . which mine is most of the time.
LostinAZ
At Home
Posted: 07/24/12 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
Have had Firestone airbags on our 2003 F250 4WD since 2006. Typically run about 30 psi in them while travelling with 38' 5th wheel. Like them a lot most of the time. One problem. The 2003 F250 4wd pickup has tongues for the overload bumpers that are located right where the Firestone bracket mounts between the airbag and the spring/axle. This causes the adjustable bracket to have to be set at its longest position to fit around the tongue. The standard Ford rubber bumper is removed from the tongue. This limits the amount of extension of the airbag in normal loaded position and when one goes over a sudden significant bump there is a chance the airbags will bottom out. Don't know if this problem exists with your truck.
Page of 5
 > Air Bags
