TheWyoCalKid
Wyoming
Acquired this trailer and looking for info on who makes it or any info in it. thank you
64thunderbolt
Az
have mvd run the plate
Glen
04 Tail gator XT 34' 5th wheel garage model
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" turbo back exh sys
trucool trans cooler added
08 Arctic Cat Prowler 700XTX
gbopp
The Keystone State
If you don't get any info maybe you can check on the Tin Can Tourists website.
OhhWell
Wow, that thing sure has some character. I'm not sure where the engineer who designed the front end learned about aerodynamics though. I guess it could be one of those cases where an artist "engineered" it. Really cool though and will definately stand out at a campground.
Any more pictures? That may help with IDing it. I know it's old but you may get lucky and find a sheet behind a cabinet door or something.
2008 Keystone Sprinter 299BHSS
2003 Ram 3500 CC DRW 4x4
RoyB
King George, VA
Went searching google images for something with similar rear design but didnt have much luck. I'm thinking 1970s vintage ...
I did find this photo but wasn't any brand name with it...
photo from google images
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
CavemanCharlie
Storden,MN
Ha Ha it's funny lookin. I hope you find some info and fix it up. I'de love to see pictures of the inside.
Lagarto_Roca
Austin, TX
It could be quite the ingenious design, reducing the low pressure drag at the rear and improving mileage.
2007 LBZ 3500 LT3 DRW Crew Cab, Sulastics, Putnam XDR 15K, B&W 30K-Turnover GN+Companion, Ride-Rite Air
1999 Layton 3125 33' 5er
Wills250psd
walnutcove NC
HIENZ 57 I like it and would love to see inside pics. Will
ShadySkins
Douglassville, PA
Tineye doesn't find any similar pictures
2011 KZ 321BHS
Pulled by a 2007 Toyota Tundra Crewmax 5.7
Connected with a Reese Dual Cam
Stopped by a Tekonsha P3
skipnchar
Topeka or somewhere else
Looks like it would REALLY create some turbulence behind it. Can't help with the brand but no doubt designed by a designer instead of engineer Surprisingly good condition though and would be interested in the manufacturers name.
