RV.Net Open Roads Forum: Do It Yourself Modifications and Upgrades (DIY): towel bar?
theniffs
Elk Grove, CA
Posted: 07/25/12 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2011 aerolite 215bhks. The bathroom is teeny (probably this way in most tt?) New to owning a TT just had a popup before and it had no potty. I need a place to hang towels. It came with just hooks above the toilet. Not fond of these because the towels dont dry well and they get in the way of using the toilet. Normally I would just hang over the shower rod but there isnt one. The curtain is hung from a track in the ceiling.
My husband hung his towel over the door when he was done, of course this did not please me as I am concerned about water damage to the cheap door. I saw an option for an over the door towel bar but not pleased with this either as our interior fixtures are mostly oiled brass and could only find chrome but also because its a cramped trailer and I dont need something else to run into.
I dont like the idea of putting holes in the walls either. Anyone have any suggestions or am I just being too picky? We are big people and use bath sheet sized towels :/
DutchmenSport
Between Anderson, Pendleton, & Lapel, Indiana
Posted: 07/25/12 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
You could try a spring-loaded shower curtain rod and put it on the wall behind the toilet and high to the ceiling No holes, and if it does not work there, you can move it somewhere else. We have 4 of these in our TT for different reasons: To hang towels, to divide the aisle to make 2 changing (private) areas, hung with just a blanket, and 2 of them to hang clip-on fans and clip on lights over the beds. Works great, no holes, no screws, and can be easily moved, re-moved, or adjusted at will. You can get them a Wall Mart or Bed Bath and Beyond. Start with just one. Should not cost but a few dollars and is a PRICELESS addition to your RV.
DutchmenSport
2005 Chevy Silverado 3500 Dually Duramax 6.6L V8 Turbo
Century Truck Cap Commercial /Toolboxes
Northeast Outfitters Canoe
2006 Keystone Springdale Model 263DBL
Weight 4985, Carrying Capacity 2575, Hitch 560, Length 30'
Width 8', Height 10' 6"
K Charles
Connecticut
Posted: 07/25/12 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
I just leave the towel on the floor
louiskathy
Oregon (presently)
Posted: 07/25/12 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
I use a sturdy six prong belt / scarf hanger. It can hang on a closet rod or you can hang it almost anywhere, including outside for a bit to dry the towels in the sun and then bring it inside.
Towels folded in half and stacked against a wall or door do not dry.
Kathy
markie mark
So Cal
Posted: 07/25/12 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
over the door hooks
06 F350 PSD CC FX4
06 Raptor 3612
00 YZ426, 02 YZ250, 02 KX85, 05 CRF70, 07 CRF50
06 Rhino 660
Member CORVA, AMA, ASA, BlueRibbon Coalition, AAPL
theniffs
Elk Grove, CA
Posted: 07/25/12 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
I dont know why I didnt think of the spring loaded bar idea! I did not like the hooks because it takes the towels too long to dry. dutchmansport thanks for the response!
Leaving towels on the floor is not an option
lots2seeinmyrv
Ocean Springs, MS
Posted: 07/25/12 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
I put a spring rod, up high, across the inside the shower. When we are done with showers I hang the towels in there with clips to dry all day.
2010 Tundra TRD 4x4 Dbl Cab 5.7L V8 4.30 Max Tow 10,300 Payload 1,640 Class IV Hitch 1,030
Prodigy P2 - Blue Ox Sway Pro 10K/1K lbs
2012 Evergreen Ever-lite 29FK
PaulaDave
New England
Posted: 07/25/12 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
I always put up a clothes line and hang mine outside but, I am going to get the spring tension shower rod to puy in the shower in case it rains
Ron3rd
Upland, CA USA
Posted: 07/26/12 06:50am Link  |  Quote  |  Print  |  Notify Moderator
We got rid of the track like you have for the shower curtain and installed the Extend A Shower rod. Solves a couple issues; gives more elbow room in the shower and as ab added bonus you can throw your wet towels over it. One of the best accessories I ever installed. See it here:
Extend A Shower
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
TXcampingfamily
San Antonio, TX
Posted: 07/26/12 08:05am Link  |  Quote  |  Print  |  Notify Moderator
Extend A Shower
I agree! We put one in a couple of years ago and love it!
Gin & Mike + 2 TD (tax deductions)
2009 Fleetwood Fiesta Bunkhouse
