rbobbitt
San Jose del Cabo,Mx. and USA
Wife and I are on our first trip in our moho 04 itasca horizon and the slides are stuck in the middle. The first slide came out fine then the others stoped in the middle. Motor runs but move very slow or not at all. It's fixin to rain and there is a lot of daylight between the gaskets. i reallydont want to try to crank them in manually. Dont know how. i would like to check the hydraulic fluid . Anyone know where the resorvoir is located. I know, I am a newbie!
Rgb
Tsalla Apopka
Crystal River, FL
Is the rig level?
Are you sure the slides are hydraulic? Some are and some are electric.Just start opening basement areas until you see the pump. Can't really check fluid level unless all are retracted (holds true for slides or jacks).
Denny & Karen
Florida's Beautiful "Nature Coast"
Brit,TDI,BH & Claire,TDI (Belgian Sheepdogs)
Merlot - Sheltie rescue
Glady(Morgan Mare - retired),Toes & Beemer(Barn Cats-retired)
WA4OMG (Old Mangy Goat)
Tsalla Apopka
Crystal River, FL
Also check the ignition switch - some rigs (mine for instance) disable the slide controls if not in Park with brake set..
rbobbitt
Thanks for the promt responses. Coach is pretty level , maybe a little low in front but this is our 8th day out and the slides have always worked flawlessly. Brakes are applyed. It is a hwh system 04 itasca horizon. Since we are planning on leaving tomorrow to golden, co i need to get the slides in and maybe have it checked a camping world in golden. Is it hard to get the slides in manually and where would the hydraulic resivior be , not back by the motor , but in one of the compartments? The hwh service manual is the only one I cant find with the cluster of manuals in the moho
Randy
Bounder Lew
fulltimer Melaque Mex , site 33 Oceanside
My reservoir is behind a tin panel in my battery compartment.
How about your jacks? the warning lite on hydraulic jacks is triggered by the fluid level being pushed back in the resorvoir by the springs. so if warning lite will go out you have low level of fluid.
A lot in Melaque Mexico in winter and Victoria BC in summer - 2000 Fleetwood Bounder 31 W
V10
03 Tracker ZR2 Towed
Excalibar Towbar and SMI Stay in Play braking
OldBlackWater
Keep on rollin'
My slides seem to move more quickly and with more force while the engine is running. Maybe try that if you haven't gotten things working yet.
Steve -- Murphy, TX
2011 Fleetwood Storm 32BH (2011 Ford F-53 V10)
2006 Honda Odyssey toad, Blue Ox Aventa LX tow bar, BrakeBuddy, cute decorative lights in the shapes of peppers and RVs, one lovely wife, and three little kids
2chiefsRus
USA Somewhere
might be low battery?
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2003 Odyssey
Fulltime since October 2007
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
rbobbitt
thanks all for the responses. today is a new day and I either have to get the slides in myself or call a mobile service to help. I would like to check the fluid level, but don't know where the resorvoir is hissen. can anyone help.....rgb
klm
SIOUX FALLS, SD
Are you plugged in to shore power? If your batteries are weak, that could be the problem.
'02 KOUNTRY STAR DP
2012 HONDA FIT "PUMPKINMOBILE"
GILLIGAN- 1ST MATE CAT - 3 HR TOUR
ReadyToGo
Minnesota
the slides need a battery to work is usually the problem.
If you aren't hooked up to electricity, connect to your vehicle and start that up. Either of those to things will get the converter running and should help solve the problem. Also, If you push on the slide while it is going in, you can speed up the process a little bit without hurting anything.
