RV.Net Open Roads Forum: 2000 Ford v10 iin need of new or rebuilt ECM ?
 > 2000 Ford v10 iin need of new or rebuilt ECM ?
JIM BUTLER
SCHROON LAKE, NY
Posted: 07/28/12 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
Good evening everyone from a newbie on this forum. .
My mechanic tells me that I need to get either a NEW or REBUILT "ECM" for our 2001 Chateau Sport 28 ft with a 2000 Ford v10 GAS. . .he and I have searched the internet with no luck. . . Anyone out there who could help or advise what a next step would be ? ? ?
My unit has been sent to Florida to be "rebuilt" with no luck when reinstalled :>( My wife and I are at a loss where to turn . . .
nalcon
SE Texas
Posted: 07/29/12 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
I took my '99 Ford F53 to Ford dealership and they replaced it.
Charlie and Sherrie
'99 Fleetwood Southwind Storm 31'
'10 Honda CRV EX-L
FMCA F417071
clydedoerr
Hardeeville SC
Posted: 07/30/12 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Take it to a Ford dealer
NewsW
US
Posted: 07/30/12 08:41am Link  |  Quote  |  Print  |  Notify Moderator
Looks like your mechanic failed to do a proper diagnostics IF we assume the rebuilt unit is good.
And I am assuming the same mechanic found the rebuilt to be good but didn't work when plugged in.
Normally, ECMs that are rebuilt / replaced need to be programmed correctly.. was that done?
I think you need a new mechanic.
carringb
Corvallis, OR
Posted: 07/30/12 08:50am Link  |  Quote  |  Print  |  Notify Moderator
Very unusual for the E-series to lose an ECM without some sort of cause, like improper welding technique, or a failed charging system, or crossing jumper cables.
Why did the mechanic think it was bad?
My local wrecking yard usually stocks ECMs for all vehicle starting in the early 90s. The usually have a few E450s laying around too. (You cannot use a van-body ECM because it will not allow 4.56 gears to be selected).
Bryan
2000 Ford E350 DRW Wagon (14-pass all captains chairs)
V10 w/ Banks PowerPack, Diablo Predator, 4.56 LS, ~350,000 miles
New Desert Fox in the works!
nalcon
SE Texas
Posted: 07/30/12 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
The ECM definitely needs to be programmed. I was told that only Ford can do it.
JIM BUTLER
SCHROON LAKE, NY
Posted: 07/31/12 09:47am Link  |  Quote  |  Print  |  Notify Moderator
"nalcon" Thanks for your response. . .the outfit in Florida supposedly got the re-program "details" from the Ford Faactory and did the "FLASH" re-programming ? ? andd the first attempt to re-install did not work. . .the ECM has been returned to Florida for a second try. . .when the unit comes back and is re-installed if it does not work then we are going to have it towed to the nearest Ford Dealer - in Saratoga Springs - as we went to them personally over the weekend and they requested that we have the RV owwed to them and they will re-check everything, in case our mechanic has "missed" something. . .the dealer wants to do their own testing to confirm whether the ECM is really the problem.
THANKS to all who shared their thoughts. . .all comments were appreciated ! ! Jim Butler, Schroon Lakae, NY
JIM BUTLER
SCHROON LAKE, NY
Posted: 07/31/12 10:17am Link  |  Quote  |  Print  |  Notify Moderator
Sir: I would appreciate if you would share an email address or a phone number for your local wrekcing yard. . .THANKS, Jim Butler
carringb
Corvallis, OR
Posted: 07/31/12 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
http://www.autowrecking.com/
