RV.Net Open Roads Forum: Class A Motorhomes: no power in coach
 > no power in coach
pianotuna
Regina, SK, Canada
Posted: 07/29/12 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Richard,
I have an automatic circuit breaker at the battery before the disconnect switch (no relay). There is a second automatic circuit breaker near the converter.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
2ndhom
Eugene, Oregon
Posted: 07/29/12 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
Some breakers don't always look like they have "poped". Actuate the main back and forth a couple times to make sure it is set.
egh33
Henrietta,Texas
Posted: 07/29/12 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
We sure have some crazy problems with these MH's This guy can't get the power ON, I can't get the power OFF. My AUX BATT switch will not shut the power off in the coach. Replaced the rocker switch with a new one. Still won't cut the power. I guess back to the shop. As I sure don't know where to go from here.
basset
gardners
Posted: 07/29/12 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
i had a similar problem with my 2005 pace arrow. had no power anywhere. checked all breakers,charged batteries as you did. turned out that the gfi outlet in the bathroom was tripped. do not know what caused that as was just setting at home. has not happened since
RLS7201
Some Where
Posted: 07/29/12 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi Richard,
Hi Don,
The breaker is a great idea but Fleetwood didn't use a breaker or fuse on that year Pace Arrow, between the battery and BCC. Most every thing after the disconnect is current protected. I have the same configuration on my 95 Bounder, just a lesser trim level.
Bob n Humble
Humble, Texas
Posted: 07/29/12 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone for all the great info. I will try to get tomy coach in the next coupl days to checkm it out but that dang thing called work may get in the way.
Still open to any suggestions
Thanks Again
Bob
comnthru
Arizone/Montana
Posted: 07/30/12 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
Check your GFI (ground fault interrupter) It is located on one of your plug outlets inside the coach
 > no power in coach
