RV.Net Open Roads Forum: Tow Vehicles: MPG comparison
Search only in Tow Vehicles
 > MPG comparison
ib516
Up here!
Posted: 07/29/12 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
BIL and I both filled up at the same station, then towed about 3 hours and filled again. We are travelling together, so the route and weather conditions were identical. Outside temps were 100f, route was I15 into Salt Lake City from the north. It is quite hilly. There was a bit of a headwind/front corner wind through the whole trip. A/C in both truck was full blast the entire way.
We drove together more or less, always within sight of each other.
His combo is a 2004 Ram 2500 4x4, Quadcab, long bed, 5.9L Cummins, 48RE auto, 3.73. He has the 305hp/555tq engine. His RV is a 32' TT - a 2008 KZ Spotsman 3204 quad bunk with one slide. UVW 7300#, GVWR 10,000#. I'd guess his RV is about 9000# loaded. His truck is bone stock. Stock tire size, no lift kit.
Here is his truck & RV.
Mine is a 2007 Ram 3500 SRW 4x4, Megacab, shortbed, 5.9L Cummins, 48RE auto, 3.73. Mine is the 325hp/610tq engine. My RV is a 36.5' 5er, a 2010 Cougar 322QBS with three slides. UVW 9540#, GVWR 11,860#. I'd guess mine is about 11,000# loaded as it sits.
I have the hypertech tuner and a 4" exhaust w/muffler. Stock tire size, no lift kit. Stock air intake.
We filled up the morning. We both took 15.18 gallons to fill ($53.00 @ 3.49/gal) at the same station at the same time. We both went 160 miles = 10.54 mpg. Real world, no BS numbers.
I would have thought he would have gotten better mpg than me as the 305hp version of the Cummins is noted for good mpg.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
dave17352
LINCOLN, NE
Posted: 07/29/12 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
Well that sounds about right. I have had a couple of different diesel tow vehicles and the mpg were pretty darn close all right in the 10 range. The only way I notice any big difference is if I go 55 instead of 65 that can save me close to two miles per gallon.
Hannibal
Gas Station
Posted: 07/29/12 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
That's about what I got with my four Cummins powered Rams. Wishing you guys happy trouble free travels!
'10 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
'07 KZ Jag 28JFSS.
timc1207
Posted: 07/29/12 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
Running close to 9,000 with my rig loaded. Keeping it about 65 I get around 12mpg in the flatlands and 10mpg in the hills.
2008 Forest River Wildwood Le 27BHBS - 2010 Dodge 2500 Laramie Mega cab 6.7L Cummins diesel, Flo-Pro exhaust, XRT Pro tuner, Mygig Lock Pick, Access tonneau cover, Ranch Hand grill guard, KC daylighters.
ib516
Up here!
Forgot to mention speed. ~67 mph.
K3WE
Missouri
Posted: 07/29/12 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
Who was in front of who? Drafting is real.
ib516
Up here!
Posted: 07/29/12 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
We were quite far apart, but within sight. He was in front most times, but about half a mile or so at least. I like a lot of stopping distance and distance to change lanes should the need arise.
tempforce
Pacific Wonderland (in the summers)
Posted: 07/29/12 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
how do you compare your throttle use. who gets into the fuel before the grade, or after they hit the grade.. air flow over the roof of the cab then over the 5vr. the trailer the air goes over the cab into the bed, then over around the trailer... he's lighter, but is actually pushing more air.. and remember how each of you drive, may be the difference..
next time trade vehicles and compare..
somewhere in the texas 'lost pines'
'83' Ford Ranger with a 2.2 Diesel, little smoke
in the workshop:
'56' F100 truck and a 60's trailer …
NavyDood
NW of DFW
Posted: 07/29/12 10:30pm Link  |  Quote  |  Print  |  Notify Moderator
Non towing yes. When towing all that goes out the window.
- Retired Navy Chief
- Vanilla 04 2500 QCSB, 4x4, 48RE w/MagHytec DD, Smarty Jr, 4" Exh, Modded Air Box, Isspro Gauges, Quadzilla RPG w/fuel pressure, DynaTrac front, Coolant By-Pass Filter
- 06 Pilgrim 30RE2SLF-5 13,300lbs loaded. B&W Companion
alboy
Kelowna B.C.
Posted: 07/29/12 10:58pm Link  |  Quote  |  Print  |  Notify Moderator
IT seems most diesels will be between 10/11 us gal travelling in the mid 60,s, i averaged 10.19 us from palm springs to kelowna in feb ,hand calc travelling at 65mph,5.9 with a tuner set at 40 hp. 23000 gcw
 > MPG comparison
