Abn1SG
Alabama
I just purchased a used 23' double axle TT and I need to replace the tires. The tires size are ST205/75D14; I would like to know if I can upsize to 15. The tire rim size is 5.50. I read on here that the replacement tire to go with is the Maxxis M8008ST; does anyone know best price online since I doubt I will find them locally; thanks.
bob213
Fresno, CA
If you have the clearance and don't mind buying new rims, yes you can. Remember, you want at least 1 inch "between" the tires. If you are going to purchase new 15" rims, I would suggest getting some that will hold at least 65# PSI so you can go to a load range "D" or "E" if you want. Shadow Trailers has some white modular rims rated to 2600# and will hold the PSI. If you have a Discount Tire or America's Tire in your area they will order the Maxxis tires for you. Otherwise you should be able to get them from DiscountTireDirect or Tire Rack online. Make sure you get the correct width rim for the tire you plan on purchasing.
Rims
edited 07/30/12 01:59pm by bob213 *
johnrbd
San Joaquin Valley
Don't forget to have stainless steel valve stems installed. Rubber ones tend to deteriorate after time and the constant bending from checking psi.
Abn1SG
Alabama
bob213 wrote: If you have the clearance and don't mind buying new rims, yes you can. Remember, you want at least 1 inch "between" the tires. If you are going to purchase new 15" rims, I would suggest getting some that will hold at least 65# PSI so you can go to a load range "D" or "E" if you want. Shadow Trailers has some white modular rims rated to 2600# and will hold the PSI. If you have a Discount Tire or America's Tire in your area they will order the Maxxis tires for you. Otherwise you should be able to get them from DiscountTireDirect or Tire Rack online. Make sure you get the correct width rim for the tire you plan on purchasing.
Rims
Thanks for the quick response guys...just checked the space between the tires and I would not have the 1 inch minimum spacing, therefore I need to stay with the size 14; thanks for letting me know.
Abn1SG
Alabama
johnrbd wrote: Don't forget to have stainless steel valve stems installed. Rubber ones tend to deteriorate after time and the constant bending from checking psi.
I would not have even thought about this, thanks.
batman99
at seasonal site
If factory ST205/75D14, you might want to investigate ST215/75D14 - ST225/75D14. Or better yet, ST225/75E14. Slightly wider and slightly more firmer (stronger). Something to investigate as well….
Kennedycamper
Algoa, Texas
Get metal valve stems on all of your tires, and then go get a tire pressure monitor system.
Bill & Kate
Stone Harbor, NJ
The "D" in ST205/75D14 is not the load rating - it designates a bias ply tire. They are usually only load range C (50psi). I would go to radial tire ST205/75R14 (here the "R" designates radial). If you have room, you can go a little wider (215 or 225 as Batman said) but you will have trouble finding anything heavier than load range C in the 14" size. The only two Load range D (65 psi) tires I know of are the Kumho (sold by Tire Rack) which comes highly recommended by the single axle guys that need the capacity, and the Chinese Kendra Karrier (distributed by Martin Wheel and sold by Northern Tool). On our previous trailer, we had 14" wheels, and the Kumhos were out of stock so we went with the Kendras. They seemed like a good heavy tire, and we ran them close to 15,000 miles without any problems.
As Bob said above, if you go to 65 psi tires, you need to check to make sure your existing wheels are rated high for the higher pressure.
and X2 on the metal valve stems, and spin balance too.
Bill & Kate - Stone Harbor, NJ
w/ Sunny (parti poodle) & Molson (goldendoodle)
2005 Ford/Quigley 4x4 E-350 Chateau Super Duty Van with 6.0L PSD ("Moby")
2012 Outback Super Light 277RL - 10th Anniversary Edition ("Salty Dog House II")
Abn1SG
Alabama
cathcartww wrote: The "D" in ST205/75D14 is not the load rating - it designates a bias ply tire. They are usually only load range C (50psi). I would go to radial tire ST205/75R14 (here the "R" designates radial). If you have room, you can go a little wider (215 or 225 as Batman said) but you will have trouble finding anything heavier than load range C in the 14" size. The only two Load range D (65 psi) tires I know of are the Kumho (sold by Tire Rack) which comes highly recommended by the single axle guys that need the capacity, and the Chinese Kendra Karrier (distributed by Martin Wheel and sold by Northern Tool). On our previous trailer, we had 14" wheels, and the Kumhos were out of stock so we went with the Kendras. They seemed like a good heavy tire, and we ran them close to 15,000 miles without any problems.
Thanks for the additional info; I called around to the different tire shops in my area and was able to find one that deals with Maxxis... He does have to order them, arrive in two days. Only size available were the standard 205/75R14...no wider ones. Shop quoted me $7 less on the price than tirerack.com; will be replacing all four tires; I informed him I also wanted fresh tires, prod date no longer than 7 months and he said he would make sure of this. He even stated that they use stainless steel valves. Definetly getting them balanced as well. Appreciate all the info and help in getting these replacement tires; just got this 07 KZ Jag II 23' from the previous owner yesterday and tires needs to go.
Will be on here frequently getting all the tips and recommendations from all you veterans. I'm glad to be back in the camping world again after a 25 yr hiatus.
