RV.Net Open Roads Forum: Class C Motorhomes: Blown fuses on Maxxair fan
 > Blown fuses on Maxxair fan
pondigger
Wi
Posted: 08/01/12 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
12 year old Jayco....last night blew a fuse...installed new one...blew it as well....any idea's appreciated....geting new fuses now....thanks
harold1946
Surprise Arizona
Posted: 08/01/12 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Check all electrical connections for loosness and corrosion including the wall switch. If everything is clean ant tight, probably the motor has gone south.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer toad
Dusty R
Charlotte Michigan 48813
Posted: 08/01/12 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
If the fuse blows as soon as it is installed, look for a short. If it blows when the motor is running it's the motor.
Dusty
rexlion
Broken Arrow OK
Posted: 08/01/12 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
A wire could have been rubbed bare, causing a short. Just a thought.
crasster
Dallas
Posted: 08/02/12 11:25am Link  |  Quote  |  Print  |  Notify Moderator
check for shorts. Any shorts will blow a fuse.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
TyroneandGladys
Chandler AZ
Posted: 08/02/12 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
Including Daisy Dukes
Tyrone & Gladys
26" 1986 Coachmen
