RV.Net Open Roads Forum: Hybrid Travel Trailers: Does it have to be level?
Open Roads Forum  >  Hybrid Travel Trailers
 > Does it have to be level?
Wavesprite
Carmel, CA
Posted: 08/02/12 08:50am Link  |  Quote  |  Print  |  Notify Moderator
We are picking up our NTU hybrid on Saturday. We currently have a PUP and one of the first things I learned on here before we got our PUP was the importance of leveling.
My question is, can we go into the hybrid and work on it, load it, etc, if it is not parked on level ground? Or do we have to level it before working inside??
Dang this seems like a silly question....sorry in advance.
coolmom42
Middle Tennessee
Posted: 08/02/12 08:54am Link  |  Quote  |  Print  |  Notify Moderator
You can work in it and load it, as long as the wheels are chocked. It will be annoying because the cabinet and bathroom doors won't stay open like you want them. Also, you need to be within 3 degrees of level (front to back for the trailer, left to right for the fridge) for the fridge to work properly while sitting still.
Level side to side with leveling blocks, front to back with the tongue jack. Remember that the stabilizer jacks are for stabilizing only, not leveling.
2006 Toyota Sienna
Single empty-nester in Middle TN
dupreet
High Point, NC
Posted: 08/02/12 09:21am Link  |  Quote  |  Print  |  Notify Moderator
You should be fine. The only issue might come in the type of 'pop outs' your hybrid has...deployment might not be advisable if the camper isn't pretty level.
Todd
Todd
1993 Ford E-350 pushed by a 1988 Wilderness 24' TT
stevenicol
Portland, Oregon
Posted: 08/02/12 09:25am Link  |  Quote  |  Print  |  Notify Moderator
...isn't leveling only necessary for the refrigerator to work properly? Otherwise, it's a moot issue.
Wavesprite
Carmel, CA
Posted: 08/02/12 09:28am Link  |  Quote  |  Print  |  Notify Moderator
OK thanks!! We won't be opening the ends up when it's not level at our house, but will want to load, etc.
Can someone answer this? I know the fridge runs on propane or electric, but what do you do when you are plugged in, the fridge is on, then you travel to another site. Do you drive with your propane on? (that seems unsafe to me) or does the constant power from the tow vehicle keep the fridge cool?
Bird Freak
Calhoun, Ga.
Posted: 08/02/12 09:32am Link  |  Quote  |  Print  |  Notify Moderator
Unless your fridge has 12 volt setting which I doubt use propane for travel.
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs-28years
We love 56 T-Birds
1995brave
San Antonio, TX
Posted: 08/02/12 09:40am Link  |  Quote  |  Print  |  Notify Moderator
Once the fridge is cold and as long as you don't keep opening the door it should stay cold for several hours.
bikendan
Napa, Cal.
Posted: 08/02/12 09:44am Link  |  Quote  |  Print  |  Notify Moderator
this is debated here and other RV forums ALL the time. if you did a search, you'd find thousands of posts on this.
bottom line, the vast majority of RV'ers travel with the propane on.
the only restrictions tend to be when driving through tunnels and this is generally in a few East Coast tunnels.
Dan- Firefighter, Shawn- Musician/Entrepreneur, Zoe- Faithful Golden Retriever, 2007 Chevrolet Avalanche LS, 2007 Rockwood Roo 23SS w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
dupreet
High Point, NC
Posted: 08/02/12 09:48am Link  |  Quote  |  Print  |  Notify Moderator
Age-old discussion/argument around here.
Most folks travel with their fridge running on gas, some turn them off at the gas pumps, and some are afraid of running them unless the camper has come to a complete stop.
I personally have mine on Automatic 7x24 whether it's plugged in at home or a campsite, or running on gas while traveling/boondocking.
Todd
skipnchar
Topeka or somewhere else
Posted: 08/02/12 09:58am Link  |  Quote  |  Print  |  Notify Moderator
FEW large refrigerators have a 12 volt option though some small ones as found in truck campers and some pop ups do have that option. turn on the LP and use it as it's designed to be used. Any time the fridge is NOT turn on (either electric OR LP mode) then NO RV is required to be level. It's all about the fridge.
