mlts22
Austin, Texas
I have encountered people who do this with their boats, but never with RVs. Have anyone heard about using 80-100 proof "rotgut" vodka, or even Everclear for winterizing? The process used is as follows:
Drain and bypass the water heater, giving the tank a good rinsing and replacing the anode rod if a Suburban model.
Blow out the lines with a dry, oil-less air compressor at 35 PSI, faucet by faucet, making sure to get the bathtub/shower, toilet, and external shower.
Pump vodka or everclear in, so it comes out all faucets. Then blow the lines out again. This gets rid of almost all water, and any that remains is a water/alcohol mix with a lower freezing point.
Pour some olive oil or RV antifreeze in the U-traps and some on the toilet to keep the valve seals OK and odors out of the living space.
The reason people use vodka is that it doesn't give the oily taste/odor, and is supposed to kill germs actively. Plus, oddly enough, it is cheaper in my neck of the woods than RV antifreeze.
Anyone hear of this method? This is a first for me, as I've not seen any RV-ers use booze for winterizing. Here in Texas, either they just drain tanks and blow the lines, just drain the tanks and leave all faucets open, or if they are going north, actually use the pink stuff.
d3500ram
colorado
...and look at the good side of when spring rolls around: just grab a bag of ice and a gallon of OJ and invite the friends over for a de-winterizing party!
Pangaea Ron
Anacortes, WA, USA
I think that I just found a use for that 2 liter box of Russian Vodka that I got in Estonia for ~$12USD.
2008 Itasca SunCruiser 35L
2000 Jeep Grand Cherokee Laredo
md2lgyk
WV
Why would you even consider such a thing?? Vodka, rotgut or not, is way more expensive that RV antifreeze. Is this thread some sort of joke??
"The great object is, that every man be armed. Everyone who is able may have a gun." - Patrick Henry
downtheroad
Pacific Northwest
I just bought a 2 gallon jug of RV anti-freeze at Walmart for under $4.00.
Man, that must be some kind of nasty vodka to be less expensive than that....
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
6.7 tow rig
kentucky
downtheroad wrote: I just bought a 2 gallon jug of RV anti-freeze at Walmart for under $4.00.
No joke. That sounds ridiculous
2012 Dodge Ram 2500 Cummins 4x4 3.73 rear end
2013 Primetime Lacrosse 318bhs
mlts22
Austin, Texas
It is less about the cost issue, than the taste/odor of the pink stuff. However, I wonder about the fact that ethyl alcohol would dry out any rubber seals it is in contact with, while the pink stuff doesn't do that.
I just have never heard about anyone using moonshine for winterizing before with RVs, but hear/read about people doing it with boats.
daveshan
Durango Colrado
First trip out I use bottled water for drinking/coffee after than no taste and I use what's on board.
I'll stick with what's designed and tested for RVs.
'99 Alpine 36SDS/8.3 ISC 330 Cummins
Or
'05 Lance 845
'06 Super duty SC/SB 6.0
Upgrades include: StabilLoads, Air Bags & Timbrens,Swaybars
Usually towing an '01 Wrangler, lifted/locked on 35"s or a mildly built '98 Cherokee on 33"s (only one locker)
bigred1cav
ohio
Sounds like it will work for me, a splash of Orange Juice and a dash of lime.
old guy
Oregon (pronounced Or e gun)
for one thing the RV anti freeze is cheaper and it only takes one gallon.One gallon of spirits is about ten times more money. I don't see the big reason or savings to this type of prevention.
