RV.Net Open Roads Forum: Fifth-Wheels: What do you use for leveling you camper?
 > What do you use for leveling you camper?
Our Place
Southwest Ohio
Posted: 08/03/12 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
We camp 3 times a year at a lake campground that is really unlevel. I have 4 2x8 boards each cut just a little longer than the other, stacked making a long ramp. The boards are about 5 1/2 feet long and take up alot of storage space. Is there a better system that will work for tandem axles? I see alot of campers struggling with those "orange" blocks and i'm affraid i'd need a bunch of those.
2001 GMC 2500HD 4x4 with 8.1 gas Allison trans
2011 Coachman Chaparral 268RLE "Campy"
LadyRVer
Posted: 08/03/12 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
I carry 4- 18" 2x12's and 2 packs of orange blocks. When I had the fifth-wheel I used the orange blocks and usually only one side would need to be built up 2
high. I put down the one layer and then second layer was 1/2 on one orange "lego" and 1/2 on the next lego. That way it made a ramp instead of trying to pull up on 2 at a time. I also used the 2x12's and with beveled edges
turned to make it flat for the center piece, it worked. Long boards could be a tad unruly and hard to store. I'm sure someone else will chime in with other better suggestions. Good Luck...
downtheroad
Pacific Northwest
Posted: 08/03/12 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
I use Lynx Levelers (those orange blocks). Light weight, easy to transport and easy to store and strong.
You can make a ramp out of them also for changing a tire.
I gave up hauling a lumber yard full of scrap wood around.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
Artum Snowbird
Campbell River, B.C., Canada
Posted: 08/03/12 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
You are really doing it right in my opinion.. The only other thing to possibly aim for is a bit of ditch digging.. Bring the rig in close to where you want it, and then dig out the high side with a pick and shovel perhaps to settle things down a bit. Fill it back in after you pull off and point to home.
Mike and Carole
2007 Snowbird 9'6" Super Slide
2005 16.6 Double Eagle
2000 F350 7.3 SC 4X4
previously 8'10" Snowbird Camper
2006 Triple E Regency 27 foot SXL SOLD!
brirene
midwest
Posted: 08/03/12 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
X2. With 2 sets, I've never come across a situation in which they don't work.
'04 Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC Lariat 4x4 DRW 4.10 LB B&W Companion Edge Insight CTS
“The trail is the thing, not the end of the trail. Travel too fast, and you miss all you are traveling for.”
-Louis L'Amour
therink
Rochester
Posted: 08/03/12 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
If site is really unlevel, sometimes I dig out depressions in the dirt for the high side wheels. Especially when the low side is on the door side. It also makes the wheels more stable. I refill them when I leave.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
azjeffh
Chandler, AZ
Posted: 08/03/12 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
If the OP is carrying 4 2X's the full length of two tires, they've got to be getting the low side up 6 inches. Not sure 2 bags of Lynx Levelers can do that.
Perhaps slabbing the wood into smaller pieces would make the "pain" of carrying them easier.
Jeff
Wonderful wife Robin
05 F250 Supercab PSD w/Tow Command
05 HR Savoy 29RKS
Old-Biscuit
Across the USA
Posted: 08/03/12 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
I carry 2X10.....two boards. One is 58" and one it 54"
Carry them in the bed of truck. don't take up any real storage.
I like the long boards cause i can just lay them down and drive on. No stacking, no ramp building.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
chesterb
Ohio
Posted: 08/03/12 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
This is what I do as well except the smaller board is cut up into 3 sections so I essentially have 4 boards. I can use the smaller boards under the jacks if I don't need them for the tires.
2011 Dodge 2500 Hemi, Crewcab, 4x4, 4.10
2013 Rockwood Mini-Lite 2306
CactusJohn
Scottsdale, AZ
Posted: 08/03/12 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
I like the Lynx Levelers. They’re more expensive than boards, but they’re lightweight and very versatile. You can get a 10-pack for about $30 at the Super Wally Worlds.
2007 Ameri-Camp (RIP) Summit Ridge SF27RK 5er
2012 F250 Lariat SuperCab, 6.7L PSD
Reese 16K Kwik-Slide with BedSaver
