RV.Net Open Roads Forum: Fifth-Wheels: Running heater in 5th wheel
 > Running heater in 5th wheel
Majikal-Joe
South Jersey
Posted: 08/04/12 11:25am Link  |  Print  |  Notify Moderator
Hi all new to the world og 5th wheels and we are wondering if you run the trailer heater going down the road as we do in the class A. I know now that I can't put water on board till SC or Ga but do we have to sleep in a cold trailer too ?
Jersey Joe and Marianne with Dale the cat. #3
tvman44
Southwest Louisiana
Posted: 08/04/12 11:44am Link  |  Print  |  Notify Moderator
Never tried it, we do run the refrigerator on propane going down the road. Down here it does get cold enough to worry about that and the 5er warms up fast.
Papa Bob
Husky 16K hitch, Tekonsha P3,
Brewurown
Morganton, NC
Posted: 08/04/12 11:51am Link  |  Print  |  Notify Moderator
Whats the point? I never used the heater while moving. With a LP furnace, electric fire place and heat strip on an air conditioner, it don't take long to warm up after you are parked.
Al
2012 3500 Ram DRW
2010 Montana Mountaineer 335 RET
Bessie the Bassett (in doggie heaven 4/10/13)
Little Bit the Terrier (in doggie heaven 5/14/12)
Taffy a Mountain Feist
Hickory Foothills Good Sam Chapter member
downtheroad
Pacific Northwest
No reason why you can't run the heater...but why burn the propane to heat an unoccupied space? Trailers heat up to a comfortable temp very quickly after you do turn on the heat.
...and why can't you "put water on board till SC or Ga?"
We always carry at least enough water to flush and wash our hands while on the road.
Arctic Fox 25Y
GMC Duramax LBZ
Blue Ox SwayPro
Coyotecprs
chicago
Posted: 08/04/12 12:01pm Link  |  Print  |  Notify Moderator
I assume you are talking about starting out in Winter and heading to Florida. I would not run it the entire time with the wind of travelling it would probably loose heat faster than sitting still. If you are worried about stuff freezing inside the trailer while travelling with it on low would require a lot less propane and it should heat up quickly from there.
2005 Dodge Ram 2500, 5.7 Hemi
2007 Jayco Jay Flight 30.5 BHS
Luke Porter
National Director
Posted: 08/04/12 12:17pm Link  |  Print  |  Notify Moderator
My slides block the vents. This causes to furnace to overheat and shut down. If your vents aren't blocked, it shouldn't be a problem.
Yep, actually drove to all of these places---in the last eight years. Missed Rhode Island and New Jersey.
Farmer David
Mattoon, ILL.
Posted: 08/04/12 12:27pm Link  |  Print  |  Notify Moderator
I have run mine when it was cold outside, I would put thermostat on 55 just to keep it from freezing in there.
2013 F450 King Ranch CC Long Box
60 Gal RDS Tank
20K B&W OEM Hitch
2013 Lifestyle 37IK
Old-Biscuit
Verde Valley
Posted: 08/04/12 12:45pm Link  |  Print  |  Notify Moderator
This would be my biggest concern......location of furnace vents. If blocked.......not a good idea.
Us out West
Eloy, AZ (winter), Reno (home base summer)
Posted: 08/04/12 12:49pm Link  |  Print  |  Notify Moderator
Why not just turn on the furnace when you stop?
Does not take long to heat up the RV.
Our Trip Journal
2012 Jayco Pinnacle (View)
36 KitchenPantryTripleSlide
MorRyde pin box and suspension, Curt Q24, Dual Pane windows, Auto Levelers, 2 AC's,and more.
2009 Silverado 3500HD 4X4 (View)
CC, Dura-Max 6.6/Allison,LB ,DRW,Amer. Tank 65 gal. Aux Fuel
Jayco-noslide
Galesburg,Il., USA
Posted: 08/04/12 01:30pm Link  |  Print  |  Notify Moderator
We haven't but I suppose you could. But why run it while on the road moving. Unless it's so cold stuff will freeze in the trailer, just wait till you're parked for the night to turn on the furnace. I have run the furnace for 10 minutes or so at a rest stop when it was way below freezing just to keep the canned goods and stuff from freezing.
Jayco-noslide
