RV.Net Open Roads Forum: Class A Motorhomes: Toilet not holding water
 > Toilet not holding water
revump
Las Vegas
Posted: 08/04/12 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
At times, my toilet bowl will not hold water ... why??
Bob
Eycom
32043
Posted: 08/04/12 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
The rubber ring in the groove around the flapper has probably dried out, preventing a good seal. Lubricate it and it will probably hold water awhile longer. If not, the seal will need to be replaced. It's a messy job, but one that you can easily do yourself if you want to save money.
RVn Full-time
talotto
College Station, TX
Dirty seal, or something stuck in the valve. Use an old toothbrush to clean it.
Dry seal, Thedford makes a seal conditioner. I get mine at Camping World, soak the seal with it, and put some in anytime you're going to leave the camper for a few hours, or overnight. I keep some in it anytime I'm not using mine for days or weeks. Water evaporates, then the seal dries out.
Bad seal. You can buy a kit and pull the toilet out to replace. Not all that difficult.
2004 Itasca Meridian 36G
2004 HD Heritage Softail
College Station, TX
therink
Rochester
Posted: 08/04/12 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
Rubber gloves and a good coat of vaseline works for mine. I suppose that could be taken 2 different ways... Lol
Seriously, it works ok. I have found that if I work the seal edges up and down for a minute or so after cleaning and lubricating it, it becomes more pliable and holds water for several months before repeating. Mine is 3 yrs old now and still works well.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
bob213
Fresno, CA
Posted: 08/04/12 10:54pm Link  |  Quote  |  Print  |  Notify Moderator
I would not reccommend vaseline. You should not use a petroleum based product on the ring. The seal conditioner or olive oil is your best bet.
hershey
Albuquerque,(fulltime) NM, USA
Posted: 08/04/12 11:07pm Link  |  Quote  |  Print  |  Notify Moderator
We really need to know what toilet you have. If it has a sliding gate type valve it might be as simple as bits of toilet paper stuck in the grove where the knife seats. A simple bent coathanger or wire will allow you to clean that out. If it has a ball type valve, it probably has a calcium deposit built up in it and a good soaking with vinegar overnight "might" do the trick. If it doesn't you need to remove the toilet top and take the rubber type gasket out and soak it in CLR for a while and clean the calcium and replace....or just buy a new gasket.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
steelpony5555
Copperas Cove Texas
Posted: 08/04/12 11:15pm Link  |  Quote  |  Print  |  Notify Moderator
Just don't put that tooth brush back in the medicine cabinet lol lol
06 Montana 3000RK
07 Dodge 3500 Dually Sport 6.7 Diesel
07 Pearl White Ultra Classic (My new Baby)
10 Chrysler 300 Touring
Texas Boomers---Stop by for a Margie some time!
Executive
Posted: 08/04/12 11:17pm Link  |  Quote  |  Print  |  Notify Moderator
or at least use a borrowed one.........Dennis
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
jerseyjim
New Jersey
Posted: 08/05/12 04:44am Link  |  Quote  |  Print  |  Notify Moderator
My Sea-Land turned out to be an absolute bummer. The company (distributor) was kind enough to send me (0ver a period of 3 years) 2 gasket kits and a water valve replacement....but NOTHING worked to keep ANY water in the bowl.
Then the "vacuum" valve blew out getting the wall wet.
Finally, a few months ago, in frustration, got rid of it. Camping World was having a "sale" on some Thetford models ($179?) bought one, installed it...and so far, it works just like it should.
RichNewcome
Fairmont, WV
Posted: 08/05/12 07:35am Link  |  Quote  |  Print  |  Notify Moderator
Mine will leak down if I let it close to gently. If I let it "slam" shut, all is well.
