campgrl
Corunna, MI
Has anyone swapped out a ceiling light fixture in their fiver for a ceiling fan? Having a fan to circulate the air better would be fantastic, but not sure how easy this would be on a fiver. I have done several in our home, even done the wiring, but I am not sure if the wiring to the light would be the same to the fan? Any help would be greatly appreciated!
RHR
Tecumseh, Kansas
Most of all celing light fixtures are of the 12VDC variety.
Get a volt meter and see if it is A/C or D/C. If it is D/C then you would have to remove the D/C source and run the A/C wiring.
Hitchhiker 2 LS RKTG 32.5
Chevy 3500 Duramax,Allison 2004 SRW
NC Hauler
Asheville NC
Mine was just the opposite...it came with a very nice Harbor Breeze 120V ceiling fan...I added a light fixture to it. My two fantastic fans are 12V. As stated above, take a multi-meter/volt meter, and see if you are getting 12V or 120V in the location your checking. When you find out what voltage is available where you want to mount the fan you would next need to make sure you have enough support in the ceiling for the fan.
Jim & Kathy
2013 Dodge 3500DRW Longhorn 4X4/CC/LB/Aisin tranny/4:10/Cummins: 385HP/850TQ
06 HR Presidential Suite 37RLQ/ 4 slide/ dual pane windows/Winegard SK3005 Satellite/Splendide XC2100 W/D
Boxers;Buddy& Sheba II
USAF 71-75 Nam Vet
WVU fan
jnharley
Anywhere, U.S.A.
The ceiling fan makes the ceiling very dirty. If we had thought about it, we would have eliminated it when we ordered our current RV. We will never use it.
2012 Dodge Dually
2012 Nu WA Discover America 355CK
WeBeFulltimers
Here & There
jnharley wrote: The ceiling fan makes the ceiling very dirty. If we had thought about it, we would have eliminated it when we ordered our current RV. We will never use it.
We are fulltiming and use our ceiling fan all the time. Does not make ceiling dirty!
Four years in previous fiver and it didn't get dirty either.
2007 DODGE RAM 2500 4x4 QC CTD 5.9 4SPD AUTO TIMBRENS PRODIGY REESE 16K KWIK-SLIDE***PACBRAKE PRXB 2012 MONTANA 3585SA
Nolan
Full-timing
Our ceiling fan makes the ceiling dirty too. Maybe it has something to do with having a carpet ceiling or the fan is to close to the ceiling over the Montana.
We quit using ours and bought a small oscillating fan from Wal-Mart. Works a 100% better.
Nolan and JoAnn
2000 Kenworth T600. (The Little Blue Truck)
2004 NuWa Hitchhiker Champagne 33LKTG
2009 Toyota Matrix
The blog.
WellShooter2
West Texas
WeBeFulltimers wrote: jnharley wrote: The ceiling fan makes the ceiling very dirty. If we had thought about it, we would have eliminated it when we ordered our current RV. We will never use it.
The fan blades get dirty and require cleaning but the ceiling doesn't. Ours is on all the time when plugged in and in our stick house the fans only get turned off to clean them. No problem with the cieling there either.
2008 2500HD D/A
2008 Keystone Challenger
bobcouch
Southeast Texas
Our Everest came w/a 120vac ceiling fan, and we use it a lot. No dirty ceiling problem, but we have had blades broken when bringing in the slides. I'm told that the torque of the blades pushing air will eventually cause the blade brackets to deform, causing the blades to sag enough to get caught by the slide.
I've had service folks at two different (competing) locations tell me this is "normal."
Not sure I believe that, but it does happen. Just something else to think about.
Bob and Honey Couch
Miniature dachshunds Tinker and Dusty
2008 Keystone Everest
2007 Dodge MegaCab w/ 5.9 Cummins
http://boggythicket.blogspot.com/
msd
Middle TN
We had a Forest River Wildwood with two ceiling fans. Both were 12V 3 speed. Worked very well and we loved them. Miss them in our new camper.
NC Hauler
Asheville NC
Doesn't make our ceiling dirty either, ours is a vinyl type ceiling...and of course, at times, you'll have to clean the fan blades, but that's just another part of maintaining things.
