Any tip's on cleaning the awning of My TT before it's rolled up? It's an electric awning so when it's open, it's pretty much level. So stuff get's on the top then get's rolled up in the awning making a mess. Thank's
Depends on what is on it....tree sap is really tough to get off.
But for-
Mold, mildew, basic dirt...a mixture of bleach, dish soap and water sprayed on and left to work for a few minutes, then hose.
Or..Tilex bathroom mold and mildew cleaner.
You can use a cheap garden sprayer. Wear old clothes.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP Our Rig Picture...CLICK HERE
if you are looking to clean it off at the end of a camping trip, before rolling it up. hubby carries a lightweight push broom, when too much stuff is on the slide or the awning he climes up on the roof with the broom and brushes them off.
if you are looking to clean a dirty awning, see the above post, that's what we do and it comes clean. depending how dirty may also need a push broom and some "elbow grease" to do some scrubbing as well.
Good Sam Life Members. Camping with two young children in a 2007 Pilgrim fifth wheel (278BHSS) pulled with a 2002 F350.
downtheroad wrote: Depends on what is on it....tree sap is really tough to get off.
But for-
This is pretty close to what the maintenance instructions said that came with my awning. It said to apply this mixture, roll up the awning for an hour which will get both top and bottom, then unroll and rinse.
2012 3055RL Big Horn - Dexter 7000 lb axles - G rated LT Tires
MorRyde, Genset, Dual Panes, 2 A/C, Yeti Package
2013 F350 DRW 4x4 Crew King Ranch
magic eraser and no elbow grease....no pressure just lightly rub it..You cab toss it on and use a brush on a pole to move it around the awning if you cannot reach
10 to 1 water/bleach solution I'm a garden sprayer bottle, add a generous squirt of Dawn. Liberally spray both sides of awning fabric with solution until soaked. Roll up/close awning and let sit for half hour. Open and rinse off with water. Rinse well to make sure all solution is off of fabric and side off trailer.
Awning should look as good as new. If awning still looks dirty, repeat process except lightly scrub with long handled soft bristle brush before rinsing.
Works great for me. The bleach will not hurt or discolor the fabric.
Steve
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
Thanks. that's a great idea. Wet it down, roll it up, open it back-up wash it off. all I have to do is figure out how to clean it before it's rolled up at the end of a trip ?
