harper223
West Texas
I'm talking mineral deposits and build up. Can I use CLR? Or would just adding an anode rod do it?
"Whatever is good to know, is difficult to to learn."
BB_TX
McKinney, Texas
RVs supply place nearby?
They make small wands to connect to the end of a water hose. Stick it in the anode hole and it sends a high pressure stream of water to flush out the tank. I use mine each year to clean the crud out of the bottom of the tank. That is the only cleaning I do.
Or you can order one from Camping World. They are cheap.
flush wand
DutchmenSport
Between Anderson, Pendleton, & Lapel, Indiana
Get a smaller diamater sized garden hose (or something like that), cut the end of about about 18 inches to 2 feet from the end that connects to the water source or another hose.
Remove the plug and/or anode rod from your water heater, turn the water spiggot on for the garden hose and shove the cut end of the hose into the hole. Move it around and it will blast out the water tank. The calcium build up will flush out the hole. No need to buy a fancy wand if you've got something laying around the house.
I use an old hose that came off the back of the washing machine. The diameter is perfect for inserting in the water heater hole.
I don't think you want to put any chemicals in your water heater. It just too hard to rinse out.
DutchmenSport
2005 Chevy Silverado 3500 Dually Duramax 6.6L V8 Turbo
Century Truck Cap Commercial /Toolboxes
Northeast Outfitters Canoe
2006 Keystone Springdale Model 263DBL
Weight 4985, Carrying Capacity 2575, Hitch 560, Length 30'
Width 8', Height 10' 6"
Old-Biscuit
Across the USA
If you have a Suburban brand..then the anode rod is necessary to prevent the tank from corroding.
If you have an Atwood brand.......no anode rod.
Regardless the tank needs to be flushed occasionally.
You can use a wand thru drain hole.
You can turn water supply on with drain plug removed....although a wand can be directed up & around.
IF you have large scaling problem......
drain tank & then put drain plug back in
remove pressure/temperature relief valve.
Using a funnel.......pour 4 gallons of white vinegar into tank
Reinstall press/temp valve.
turn on water supply slowly and hold press/temp relief valve open
when water comes out PRV.....let PRV snap close
turn on water heater.....let it heat/cool thru 4 cycles (use electric and/or gas)
Then drain/flush tank thru drain hole.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
JJBIRISH
Butler, PA, USA
Best thing is to drain and flush it more often so it don’t get to bad… I do mine 4 times a year by removing the drain plug and opening the supply line… then I remove the relief valve and use a wand through the 2 openings… and a final flush through the drain valve and the supply line open…
If I have a lot of junk come out I would follow with what Old Biscuit said to do with the white vinegar…
Love my mass produced, entry level, built by Lazy American Workers, Hornet
Artum Snowbird
Campbell River, B.C., Canada
I fill mine up until it comes out of the relief valve, then remove the anode rod and into the stream I put a used toothbrush and swish it around inside. Almost all of the sediment will come out with the rush.
Use the relief valve as a tap... the water will gurgle out when it's closed if you have all the taps and everything closed inside the unit, but once you open that relief valve it shoots out a stream about five or six feet.
Mike and Carole
2007 Snowbird 9'6" Super Slide
2005 16.6 Double Eagle
2000 F350 7.3 SC 4X4
previously 8'10" Snowbird Camper
2006 Triple E Regency 27 foot SXL SOLD!
Lalair
Oregon
I used CLR on an old aluminum fresh water tank to clean out the sediment and buildup. The CLR did a lot better cleaning than the apple cider vinegar. After serval flushings of water, I decided not to use the tank anyway and replaced it with a brand new fresh water tank. Thats because my GF said she would never drink out of that tank after CLR cleaned it.
Since it is just a (aluminum) hot water tank, another aggresive cleaner is aluminum wheel cleaner that uses phosphoric acid (the same phos acid used in soda pop in small PPM). Just dont leave it in very long. Can test with ph paper after flushing to make sure it is decontaminated.
DutchmenSport
Lalair wrote: I used CLR ... After serval flushings of water, I ... replaced it with a brand new fresh water tank. Thats because my GF said she would never drink out of that tank after CLR cleaned it...
Oh ... I agree 100% with your GF!
mobeewan
Hampton, Va
CLR is recommended for cleaning automatic drip coffee makers so I don't think it will hurt you if you flush the water heater tank well after cleaning it with CLR.
