RV.Net Open Roads Forum: Travel Trailers: new to this
 > new to this
kenandlisah
florida
Posted: 08/08/12 01:52pm Link  |  Print  |  Notify Moderator
i have 1500 chevy silverado 5.3l just bought a 26ft tt. weight about 3900 lbs i have a weight distribution hitch do i still need a sway bar? thanks. Ken
jamstoyz
Chesterfield MI
Posted: 08/08/12 02:03pm Link  |  Print  |  Notify Moderator
you dont need one but I would highly recommend one. You'll know what I mean if you drive it without. They help tremendously.
2001 Gulfstream Yellowstone 29'
1999 Fleetwood Prowler TT 24' (sold)
2004 Fleetwood Gearbox Toyhauler 28' (sold)
APT
SE Michigan
Posted: 08/08/12 02:25pm Link  |  Print  |  Notify Moderator
I would throw away the WD hitch and get another one with integrated sway control. Actually, I would add two friction sway bars for $60 and try it first.
2012 VW Passat TDI
2017 Subaru Outback 3.6R
kenandlisah
florida
Posted: 08/08/12 02:29pm Link  |  Print  |  Notify Moderator
friction sway control huh? ill check into that. thanks for the help.
Bonefish
Midland, TX
Posted: 08/08/12 02:33pm Link  |  Print  |  Notify Moderator
Before throwing anything away; What model of WD hitch do you have?
Most have a place to mount a sway bar kit.
If the trailer and truck are level or trailer slightly nose down when hooked up you might try towing without a sway bar. You only need one if the trailer has some sway. A well aligned setup will tow fine without it.
Cedarhill
Deep South
Posted: 08/08/12 02:34pm Link  |  Print  |  Notify Moderator
A sway bar is the same thing as friction sway control. With a trailer that weighs less than 5000 pounds, I doubt you need but one.
skipnchar
Topeka or somewhere else
Posted: 08/08/12 02:59pm Link  |  Print  |  Notify Moderator
I would recommend an anti sway system. When the trailer is going crazy behind you is a poor time to go shopping for one. A single friction bar should be a good investment for your trailer. Not as HANDY or effective as integrated anti sway but it is recommended for trailers up to 26 feet in length. It does not produce as much force to maintain the connection in a straight line as integrated systems but I used one for many thousands of miles with my 25 footer.
Good luck / Skip
kenandlisah
florida
Posted: 08/08/12 03:14pm Link  |  Print  |  Notify Moderator
dont have a weight distribution hitch or sway control yet but looking at getting some views on which to get and the proper way it should be set up.
kenandlisah
florida
Posted: 08/08/12 03:17pm Link  |  Print  |  Notify Moderator
going to Martinsville Va. in Oct from Fl. just want to be safe thanks.
MitchF150
Puyallup, WA
Posted: 08/08/12 03:34pm Link  |  Print  |  Notify Moderator
* This post was edited 08/09/12 10:10pm by MitchF150 *
 > new to this
