RV.Net Open Roads Forum: Looking to buy "Liquid Roof" & Eternabond
 > Looking to buy "Liquid Roof" & Eternabond
lampooner
South Carolina
Posted: 08/08/12 02:26pm Link  |  Print  |  Notify Moderator
Looking to buy "Liquid Roof" and Eternabond 4" or 6" tape for my MH.
Does anyone have suggestions where to buy based on price, speed of shipping and customer service?
Thanks in advance for suggestions.
Lampooner
Remember you are only young once,
but you can be immature forever!
tandkj
Full timer
Posted: 08/08/12 03:06pm Link  |  Print  |  Notify Moderator
Contact PPL in Houston or look on the internet for PPL RV. They have goode prices and great shipping.
Tis another fine day to serve in and for the glory of the Corps. Every day is a holiday and every meal a feast.
08 Camelot Custom build
07 Ranger Toad
One Golden Retriever at the Rainbow Bridge and a new one traveling with us.
sc3283
St Louis
Posted: 08/08/12 10:27pm Link  |  Print  |  Notify Moderator
Local RV dealer?
04 D-Max Crew Dually
96 Monaco Dynasty 36'
Golden_HVAC
Fulltime, CA, USA
Posted: 08/08/12 10:51pm Link  |  Print  |  Notify Moderator
This is what I did to my roof, and there is a link in the post about Eternabond and liquid roof.
http://forums.woodalls.com/Index.cfm/fuseaction/thread/tid/24993453.cfm
Fred.
Gale Hawkins
Murray, KY
Posted: 08/08/12 11:14pm Link  |  Print  |  Notify Moderator
This is the source I used for Liquid Rubber. Their Liquid Roof is good too.
Eternabond Web Seal is the version of Eternabond that you will want to use if using Liquid Rubber/Roof line of EPDM in a Can. It does not have the same limitations of the PVC version of Eternabond. I used a source from AZ and IL and cost was about the same both places.
Never needed to use customer service but did check with EPDM Coating to confirm Liquid Rubber and Liquid Roof were the same basic products except Liquid Rubber is more white. One is sold through the building supply industry and Liquid Roof is sold through the RV service center industry at a higher price as of three years ago.
lampooner
South Carolina
Posted: 08/13/12 04:45am Link  |  Print  |  Notify Moderator
Thanks for input. I have orderred Liquid Rubber and Eterabond Web Seal.
Gale Hawkins
Murray, KY
Posted: 08/13/12 09:48am Link  |  Print  |  Notify Moderator
lampooner just as a note I had Eternabond Web Seal applied for up to a year before coating it with Liquid Rubber with no down side that I could detect. I am sure that would not be the case as some point in time.
The reason I mention it is so you know you can run with just Web Seal as you work on sealing any leaks or just covering weak looking spots in the old rubber roof. After sealing all openings we went end to end on both outside edges hoping the glass band will make the roof more 'limb' resistant. [emoticon]
TxTiger
North Texas
Posted: 08/13/12 10:10am Link  |  Print  |  Notify Moderator
BarneyS did his roof with liquid rubber and has a really good write up on this. I recommend you search the forum for his write-up, or possibly he will read this thread and post the link for you.
Good luck with your project.
2000 F250, 7.3 PSD, 6 speed manual, CC, SB
2013 Northstar TC800
