RV.Net Open Roads Forum: Towing: One more link?
Search only in Towing
Open Roads Forum  >  Towing
 > One more link?
bigbullelk
Atlanta
Posted: 08/09/12 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
Bear with me. I recently had my TT serviced b/c I felt I wasn't getting the braking I should have. Turns out the front wheel brakes were shot. I bought my TT used and used it less than 6 times in the 8 months I've owned it so I don't think it was the slight nose down position that the dealership set me up w/ when I bought it that burned up the brakes (the TT was 4 years old when I bought it). Guessing it was the previous owners setup.
So, the dealership that fixed the brakes (which was recommended to me by several people at work) helped me relevel the setup. Problem (maybe) is that when they flipped my Blue Ox WDH the setup was slightly nose up because there were no more adjustment holes left - I guess you'd say it was bottomed out. The tech that helped me said it was ok b/c once I load the TT up it would even it out. If I recall, I think he said it was less than 1/2 inch out of level (I saw him measure).
I've noticed that it is much easier to install/uninstall the 1000 pound bars now having two links left over. I don't have to crank up the back of the TV as high to alleviate the tension on the bars.
I wonder if I should increase it to 3 links? I did try it on the way back from camping last weekend and seemed to notice that there wasn't as much bouncing -- seemed to ride a bit smoother.
Any thoughts?
JBarca
Dublin, Ohio, USA
Posted: 08/09/12 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I'll see if I can help.
From your post, you have 2 totally different problems going on. The WD on your truck may not be set correct and you had a brake problem or still do.
I cannot make the connection on how a trailer high or low will cause the front brakes of a TT to "burn" out in short order. Being real high or real low can affect springs and tire loading but brakes? I cannot see that or need someone to explain technically how they came to this conclusion.
What can burn out a set of brakes is miss adjustment. If they are over tightened then they wear all the time until the wear creates clearance. Or the rear brakes are not doing much of anything and the front ones are doing all the braking.
All 4 brakes need to be adjusted to come on at the same time. If not the one adjusted the closet (tightest) will heat up real fast. That one brake is trying to stop the entire camper and obviously it cannot so it wears faster first.
Here is something to help sort this out. You can do a stop test on gravel and have some one watch you stop from going 5 to 10 mph. Go 5 to 10 mph and put the brakes on firm. The spotter will see which brake locks first or at all. You will need to do this a few times to try and not lock up but come real close to lock up. And when you find the tightest one locking up first, crawl under a go 2 clicks less adjustment and try it again.
Then once your past this, go for a road test. Try to not stop a lot as stop and go heats up brakes fast. When traveling to camp come to an easy stop at a rest area. Feel for heat on each hub or brake drum. Do not touch, come close and feel radiant heat. If it is not burning hot then touch. All 4 wheels need be to close to the same heat. If you have a hot one, it is braking harder then the rest. Crawl under and un-click 2 clicks. Test again a the next stop. Be careful on the heat feeling. A hot brake can be in the 200 F plus range and burn. I have one of those infrared heat guns in the cab. They work great and you can see the 200F brake and the 130 F one. I shot through the wheel spokes to the drum OD.
If you are not one to adjust the brakes, you can at least feel for heat and find out if you have even or heavy braking on 1 or 2 wheels to tell the dealer that brake is over working. I do this heat check often when we we stop while towing. You can keep looking all the time. A cold brake means it is doing nothing, a wire broke, something in side froze up etc. A hot brake means it is over adjusted or something broke keeping it on. Simply feeling for even heat helps you know things are working right or not.
Now to your WD hitch. Since the WD bars snap up so much easier, that points to less weight transfer. That may be that you were over adjusted before, it was closer to right or now your not enough weight transfer. Do you know the fender heights of front and rear, hitch with WD engaged and then unhitched? You need to know these numbers before adding or subtracting links or hitch head tilt.
On the top of this towing forum are 2 sticky notes. One on how to set up a WD hitch, the other on trailer brake service. See both to help explain more on both areas. Your WD hitch may not be setup optimum yet.
Then come back and ask more questions to help get your setup optimized.
Hope this helps
John
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
skipnchar
Topeka or somewhere else
Posted: 08/09/12 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
Set the trailer up level. Being nose up or nose down won't have any effect on brake wear but it CAN cause towing instability. Slightly nose down is better than nose up but level is even better. Your brakes probably wore out due to adjustment issues.
bigdaddyf350
SoCal
Posted: 08/09/12 11:03pm Link  |  Quote  |  Print  |  Notify Moderator
When I dealer or a shop levels your toyhauler how or where are they actualy measureing to ensure it's level?
Ron Gratz
full time RVer
Posted: 08/10/12 05:23am Link  |  Quote  |  Print  |  Notify Moderator
The trailer should not be set to "level" unless the surface it's sitting on is level.
The hitch should be adjusted so the trailer the is parallel to the surface.
The distance from a fixed elevation on the trailer, such as the underside of the frame, should be the same front and rear.
The tow vehicle and trailer should be loaded as for camping when the hitch is adjusted.
Ron
bigbullelk
Atlanta
Posted: 08/10/12 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
I believe this to be the case.
bigbullelk
Atlanta
Posted: 08/10/12 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
JBarca wrote:
Hi,
Hope this helps
John
Thanks, John. Re: the WDH, as you suggest, I need to take the fender measurements and then report back.
 > One more link?
