RV.Net Open Roads Forum: General RVing Issues: H20 pump use
 > H20 pump use
alisk
Illinois
Posted: 08/10/12 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
When hooked up to CG water that has low pressure, is it OK to occasionally turn on the H20 pump to supplement water pressure...like when taking a shower?
Thank you in advance for your reply(s).
J and A
coolbreeze01
Redding, Ca
Posted: 08/10/12 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Just make sure there is water in the tank for it to pump.
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis ST Tires.........
Old-Biscuit
Across the USA
Posted: 08/10/12 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
Yes.......both sources (hose/water pump) supply your rv plumbing system.
Discharge pressure of pump is typically 45# so if the cg hose pressure is less then the water pump will run and supply your needs.
There is a check valve in the inlet water connection and an internal check valve inside pump. These check valves prevent water from flowing backwards.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
bukhrn
Lanexa, Va
Posted: 08/10/12 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
I've never actually been to a CG with lower pressure than the onboard pump. Are you sure that you don't have some sort of blockage in the city water hookup side of your RV?
2007 Forester 2941DS
2005 KIA Spectra
opnspaces
San Diego Ca
Posted: 08/10/12 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, as Coolbreeze says you need to make sure there is water in the tank or it won't work.
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
skipnchar
Topeka or somewhere else
Posted: 08/10/12 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
As long as you have water in your tank you can use that water ANY time you want to. The pump is not likely to increase the PRESSURE water though but it can draw water from the tank instead of the pressure outlet provided it has more pressure than the water connection has. If it doesn't have more pressure it is unlikely to even turn on.
N3YMY
Brunswick, MD
Posted: 08/11/12 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
Never been to granite hill camp resort at Gettysburg, PA I take it ...?
bukhrn
Lanexa, Va
Posted: 08/12/12 11:36am Link  |  Quote  |  Print  |  Notify Moderator
No, actually, we went to Artillery Ridge. But that doesn't solve the problem, I asked about your city water hookup because there have been folks on here that have found clogged screens in the hookup, kinked lines in the system, both of which will result in low pressure.
paulm999
Pala, California
Posted: 08/12/12 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
The key thing is.....if the check valve at the city water inlet on the RV is NOT working, you will be pumping your water out to the city side. Based on all the RVs I've had, the check valves never work properly except when brand new. If your in a situation where the city side has low water pressure, why not just close off the city valve and use your own fresh water tank and pump? The Rv pump produces a flow rate as good what you can expect in a city line.
ryoung
Indiana
Posted: 08/12/12 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
It's not likely you will get additional flow by turning on the pump, that is any additional flow beyond what the pump normally delivers by itself.
If the pump supplies more pressure than the campground supply water pressure, then the pump will block any flow from the campground hookup.
Normally, you can't combine two streams of water if there is a pressure differental.
ryoung
2004 Dodge 3500 Dually HO CTD 6 sp 4.10
2004 Lance 915
 > H20 pump use
