aeohio
New Mexico
Any suggestions the valve will not close all the way after I dumped the tank. it will close but the last 1/4 - 1/2 inch will not close.
Any thoughts on what I could do. I have an enclosed underbelly so taking it apart is sort of a chore.
Thanks
2010 Passport UL 290BH
2006 Ford Expedition Limited
exeter_acres
North of Atlanta, GA
there is probably "debris" in it... could try flushing it from either end...
but may need to remove it.. clear the "Debris" and put it back....
jamstoyz
Chesterfield MI
Maybe try to install one of these and give it a good flush.flush valve
2001 Gulfstream Yellowstone 29'
1999 Fleetwood Prowler TT 24' (sold)
2004 Fleetwood Gearbox Toyhauler 28' (sold)
Ron3rd
Upland, CA USA
You could also disassemble the valve and rebuild it with a rebuild kit. But most likely something is jamming it from going fully closed.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
hallock5
Inexpensive solution.
2008 Jayco Eagle Superlite 28.5RLS
2002 Ford 4x4 SuperCab 7.3 (Jr International) Diesel
Sad to say, time to sell to a good home.
rockhillmanor
On the Road
I JUST went thru this and had the valve replaced. Got tired of trying to bang the dang valve closed so it went in all the way. When I took the valve out it worked just fine pushed in and out smoothly and no there was no clog.
I was then told by mobile repair that screws too tight will do that. He said 9 times out 10 when its hard to push the valve in, loosening the screws a bit will rectify it.
And NO that won't cause it to leak.
And I'm angry because the replacement valves are made like cheap junk and the first guy left with my original ones.
"We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us".
skipnchar
Topeka or somewhere else
Use a length of coat hanger and clean out the groove it slides in and it should close again. Most likely cause is a bit of TP getting caught in the groove. Might also consider changing brands of TP to something that degrades better.
Good luck / Skip
Carolina Cruiser
East TN
Just had the same issue and on mine it was the cable. My repair guy adjusted the cable on the valve and that was that.
Albert & Tamara, the dogs Casey & Cody, Living the simple life.
God never said Saved by Grace;kept by performance.
tvman44
Southwest Louisiana
I'd try loosening the 4 screws holding the 2 halves of the valve together, like mentioned too tight will cause that.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Johnworth914
USA!
The rubber seal could also have come partially off and is preventing it from closing. Unless it is one of the expensive cable valves, I would not bother with rebuilding kits. A new valve will only cost $20 and takes 10 minute to install
Alaska is next! Still trying to fit the pontoons to the RV so We can get to Hawaii!
