RV.Net Open Roads Forum: Travel Trailers: Help with prodigy brake controller
 > Help with prodigy brake controller
RCMAN46
NorthWest
Posted: 08/11/12 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
Specialreserve wrote:
So I went out and set the power setting to 13 and didn't come close to locking the brakes up. I have it around 9 now and that seems to be the number where I can't feel the trailer pushing. I also tried the boost feature and I had it on boost 2 and that seemed real nice. I'm a little worried that when I had the power setting all the way up that the brakes didn't seem to grab as much as I thought. Should I be worried? Being that this is our first tt I don't know what to expect when using the manual knob and activating the brakes.
If the brakes were not locking at 13 why did you lower it to 9? Try with gain at 13 and no boost. If you do not feel the trailer braking when stopping in city traffic that is the setting you should use. You want enough gain that there will be adequate trailer braking if you ever have to stand on the brakes because some idiot has cut you off someday.
I have found mine works best with no boost in city traffic. I use boost 2 on the highway for times I may have to stand on the brakes.
Terryallan
Foothills NC
Posted: 08/11/12 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Honestly guys. Mine do not lock up, Especially on pavement. I can feel them stopping the TT pretty hard when I pull the lever. I found that with the new TT. after the brakes warm up. 5.5 is close to right. No they don't lock up. But they do stop the TT, Anything more and they jerk the TV. They should not jerk the TV. How do I know they are working. I had a hard stop, and I could hear the TT tires crying under hard braking. But again. they will not lockup with the lever.
Terry & Shay
Coachman Apex 288BH.
04 F150, 5.4, Lariat SuperCab
Lazy Campers
jmtandem
western nevada
Posted: 08/11/12 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
A properly set up Prodigy is a set and forget. The suggestion to set the boost was all wrong.................. I use boost only on the highway. When in heavy stop and go city traffic or parking trailer in a trailer site I have no boost.
RCMAN,
Adjusting the boost as you say you do changing from highway mode to local street or campground mode makes it NOT a 'set it and forget it' controller for you. You contradict yourself in the same paragraph while agreeing with others that said the controller is not a set it and forget it unit. Also, your advice is not consistent with the instruction manual that provides for boost levels by trailer weights for the controller to work properly.
I do agree with you that some trailers will not lock the brakes. That is clear in the instruction manual as well. Also, brakes need to be correctly adjusted, warm, and all the wiring in good condition for the brakes to get the voltage they need. If somebody has to use 13 for the power amount then the boost is wrong, the wiring is in need of attention, the trailer connector needs attention, the brakes are not warm or the brakes are not adjusted correctly. It is NOT safe to travel and be using a setting of 13 and not have satisfactory braking. When the manual lever is activated the brakes need to work as there is no time for messing around with boost numbers in a need to stop now situation.
* This post was last edited 08/12/12 08:44am by jmtandem *   View edit history
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
'09 299bhs Tango.
jmtandem
western nevada
Posted: 08/11/12 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
It does not sound to me that there is anything wrong. The trailer brakes stop the trailer, the truck brakes stop the truck and the truck is not stopping both so it is all good. Mine is the same way when I turn the controller down for in town driving, otherwise it is very jerky and trailer tires are sliding on the pavement.
jmtandem
western nevada
Posted: 08/11/12 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
You will want good stopping brakes if you need them in a panic situation. Do not drive around with 13 set and still having poor braking action. Set the boost to '2' and try it again. Why lower the value from 13 to 9 if at 13 your braking is inadequate? Makes no sense. How heavy is your trailer and how hard were you standing on the brakes. Also, what value were you seeing on the controller when braking. It should give you a read out for the current braking voltage. Try standing harder on the brakes and see if the braking is better after warming up the brakes with some repeated braking at 25 mph or so. Make sure you are in an area where there is nobody behind you and you can determine what is happening.
If your trailer brakes have rust on them from sitting too long or if it is brand new and has been sitting on a dealers lot for some time then you might need a few hundred miles to get the brakes to work perfectly.
