RV.Net Open Roads Forum: Truck Campers: DC Power question
 > DC Power question
DiscoChicken
Lawrenceville, GA
Posted: 08/15/12 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
I have a few electronic toys that have DC wall wart power adapters. I was wondering if I could somehow hook these up to the DC system of the Truck Camper.
An example adapter:
Input: 100-240V ~50-60Hz 600mA
Output: 7.5V-... 2140mA
I've searched Google for DC power plug, but all I see is cigarette lighter sockets or more wall warts. I figure I would need a fuse or someway to get the voltage to match the requirements of the electronic toy. In other words in can't be connected straight to the battery; Right? I am currently using an inverter for these things, but it seems to me running it straight to DC would be more efficient. Any help would be appreciated.
Adventurer/Ford
KD4UPL
Swoope, VA
Posted: 08/15/12 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
There are devices to do what you want. Radio Shack used to carry them but I haven't shopped there in years.
A fuse won't reduce the voltage, you need a voltage regulator for that. Try looking for a "universal DC adapter". It will be a device that plugs into a lighter jack, has a switch to select the proper voltage, and various plugs to put on the end of the wire to fit different appliances.
Eliminating the inverter would indeed increase the efficiency.
pianotuna
Regina, SK, Canada
Posted: 08/15/12 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
What you are looking for is called a DC to DC converter.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Kalabin
Alaska
Posted: 08/15/12 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
What the others have said is correct.
In the telco industry we use -48V DC battery plants to power our equipment / lines. However most cell sites use a +24V system. To get around this we use DC - DC Converters that take the source voltage and step it up or down to the voltage required. When we wire these up we wire it off of a circuit breaker that is connected to the +24V DC buss. The breaker is limiting total current to the circuit. Our systems typtically go like this.
+24V Circuit Breaker (5-100amp) > DC-DC Converter > -48V Fuse Panel (not to exceed DC-DC Converter max amperage > wire -48V device from GMT Fuse position.
For your situation your looking to get 7.5V DC with a max current of 2.14Amps. The only down side to this setup is if you had multiple DC Devices that required different voltages that you would want to connect directly this way.
2008 Chevrolet Silverado 2500HD 6.0, 3.73, Firestone Air Bags, CCSB LTZ
smkettner
Posted: 08/15/12 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
I power my tv, dvd, laptop and charge small items with a Go Power 300w sine wave inverter.
I mounted the inverter behind the fuse-breaker panel. 12v connects to the main battery feed to the panel. 120v is wired into the entertainment area circuit with an automatic transfer switch. The wiring is very straight forward if you have done any home wiring before. The Go Power 300w has a provision for a remote power switch so with the touch of a button I have instant power.
GP 300w SW $172
Xantrex 15 amp switch $49
So all in maybe $250-$300 for self install.
Or you might get by fine with a $25 ~100w MSW inverter.
675 watts solar
Lynnsr
Colorado
Posted: 08/15/12 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
Disco, you do not want to go thru a AC converter.
Try This Link
you can tie this direct to the RV 12 volt system thru a fuse preferably.
Lynnsr
K0LFM Call Sign
Northern Lite 8-11 Q Classic SE
Pro-Craft 180 Bass boat
2003 GMC Sierra 2500, Torklifts & Fastguns, Ride-Rites w/dual Control, Helwig rear sway bar,QD Stable Loads, "E" rated 16" 10 ply Michelins, Heavy Duty Pads & Rotors
Chuck and Di
Ontario, Canada
Posted: 08/16/12 03:19am Link  |  Quote  |  Print  |  Notify Moderator
An example adapter:
Running directly from the battery requires some knowledge of what you are doing, or you will be shopping for new toys. The example you gave of needing 7.5V would cause the magic smoke to leak out if you connect it to the 12 V battery directly - even through a fuse.
Honestly, the best thing to do is keep using the inverter. These things are pretty efficient these days. The amount of energy you would save by building DC-DC converters is pretty trivial, and not worth the effort or risk. Don't forget the continuous changes in toys too - new cell phone, etc. will likely require still more DC-DC adapters.
DWeikert
York, PA
Posted: 08/16/12 05:02am Link  |  Quote  |  Print  |  Notify Moderator
Try This Link
Lynnsr
X2
This is exactly what DiscoChicken needs. Odds are there is a 12V socket this can be plugged into that is already fused.
Thanks for the link!
Dan
2008 Chevy D/A 2500HD ECSB
2010 Northstar 8.5 Adventurer
KD4UPL
Swoope, VA
Posted: 08/16/12 05:05am Link  |  Quote  |  Print  |  Notify Moderator
Well what do you know. Radio Shack still has these things. I looked it up for you.
Here's what you need:
http://www.radioshack.com/product/index.jsp?productId=3875414
camperpaul
Wherever I park my travel trailer
Posted: 08/16/12 05:18am Link  |  Quote  |  Print  |  Notify Moderator
Clicky
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
1982 6.2L Diesel Suburban 1500
 > DC Power question
