RV.Net Open Roads Forum: Tech Issues: Replacing Power Awning Arm
 > Replacing Power Awning Arm
TheZacGustafson
Aurora, IL
Posted: 08/16/12 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
A couple of weeks ago while we were sleeping a deluge came and my awning arm broke. I have a new arm but not sure how to get into the walls to reconnect the wiring. I was going to look behind the exterior light before I cut a hole in the interior wall. If I do need to cut a hole I was looking for the best way to reapir it. I was going to get an access panel to cover the hole and give me access if I ever had to get to the wiring again.
Any help would be appreciated.
Zac
* This post was last edited 12/28/12 12:06pm by TheZacGustafson *   View edit history
2012 Starcraft 309BHL Autumn Ridge
2011 Ford Expedition EL XLT
rving4us
SC
Posted: 08/16/12 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
Zac, every electric awning I've seen had a mplug on the camper and you just plugged the awning motor into it. That is the way mine is set up even though I ordered the manual awnings on my new camper so I could tie them down and leave the awning up in bad weather. But if yours is not that way I would add the plug once I found the wires.
Cary
2007 GMC classic,Dmax/Allison, CC,DUALLY,4X4 3;73, (((xm))) pulrite 25.5 hitch
2011 Carriage Cameo37ks3,17.5 tires,disc brakes,plus every option except generator
sharker6
fulltime KY, NC, FL, MA, TN
Posted: 08/16/12 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
My new awning arm came pre-wired. All you need to do is connect your wire coming from the TT to the new wire, It's an easy job. Look on ebay, I got mine for 1/3 what the parts places charge.
2009 30' Fleetwood Wilderness, 2008 F-250 Super Duty FX4 stump puller
TheZacGustafson
Aurora, IL
Posted: 08/18/12 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
I found where the awning wired into the trailer. It was behind the key holder.
The key holder.
The wiring behind the key holder.
It wasn't nearly as difficult as I thought it would be. The new arm used the exisiting holes and hardware with the exception of the top hole. The lag screw was pulled out so I drilled a new hole an inch above the other hole and installed it there. Then it was a matter of sticking the wires into the hole and pulling them inside. A couple of wire nuts and a quick test to make sure the wires weren't crossed and the job was done.
FYI the idler,or non-drive, arm is the same as the drive arm and cheaper. You just need to remove one screw to remove the idler head and replace it with the drive head. Luckily the arm was the only thing damaged and not the drive.
Hopefully this helps,
Zac
