RV.Net Open Roads Forum: Thoughts on Deltran Battery Tender 5-10-15 watt solar units
 > Thoughts on Deltran Battery Tender 5-10-15 watt solar units
41woodie
Oklahoma
Posted: 08/18/12 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Just looked over the Deltran website trying to select a unit to charge the house batteries on our Born Free and saw that they are now offering solar powered units in 5-10-15 watt sizes. They also sell a small controller for use on other solar panels that is compatible with their chargers.
From the very little I know about solar units I would think that the Deltran units would be small for the job but would appreciate any thoughts or if anyone owns one of these how would you rate them. thanks mh
'09 Coachmen Freelander 3150SS
2000 Jeep Wrangler Sahara Edition Tow'd
Blue Ox towing system
pianotuna
Regina, SK, Canada
Posted: 08/18/12 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I find that 12.5 watts per 100 amp-hours is the bare minimum needed for maintenance charging only.
It is probably best to "roll your own" with an inexpensive controller and 50 to 135 watt panel.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
2oldman
Winchester WA
Posted: 08/18/12 09:53am Link  |  Quote  |  Print  |  Notify Moderator
Depends on what you mean by "charge". Trickle, overnight, 4 hours?
garym114
Bluff Dale, Texas
15 watts is not enough. You would be disappointed.
41woodie
Oklahoma
Posted: 08/18/12 10:53am Link  |  Quote  |  Print  |  Notify Moderator
That's what I thought, the units are probably fine for keeping a stored unit's batteries fully charged but not big enough to recharge units in use while dry camping. thanks
jauguston
Bellingham, WA
Posted: 08/18/12 11:22am Link  |  Quote  |  Print  |  Notify Moderator
15w would not be enough for even a stored unit unless the batteries were physically disconnected. There are enough "phantom loads" on most RV electrical systems that will drain the batteries over time even with a 15w solar panel.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
