RV.Net Open Roads Forum: Beginning RVing: Roof Damage
 > Roof Damage
atvaholic
Niagara Falls
Posted: 08/18/12 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I was cleaning my trailer and noticed some roof damage.
The trailer was purchased new a few months ago, and I have no idea what could have caused this. Does this look like a warranty issue, or does int look like I damaged it?
The problem is I have a trip planned on thursday...not sure if I have time to get this fixed by the dealer. Is it an easy fix? Or should I wait for the dealer (not in until monday )
Some more pics:
fordsooperdooty
Posted: 08/18/12 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
Easy fix...get a piece of EternaBond Tape from WalMart, or a RV Parts and Supply Store..or even a Roofing Supply Shop and follow directions.
It LOOKS like it's from the inside...maybe some fasteners or screws came thru the material from beneath...so take care of that first. Not worth the bother to take it to the dealer and the EternaBond will last forever.
Follow the directions!
Mocoondo
Chicago, IL
Posted: 08/18/12 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
I'd say you snagged a tree branch.
The problem with Eternabond in this location is that it's on a corner and will have a greater propensity to peel up.
If you really want to Eternabond it, I recommend that you unscrew the awning rail and put the edge of the Eternabond under the awning rail and then drape it up over the corner.
For a quickie repair, you can take a tube of Dicor and use it to "seal" the small tears. Then after your trip, you can take some time and rethink what the permanent repair will be.
If there are indeed exposed fasteners under there, they would likely be staples and then I would personally insist on a new roof under warranty. A brand new RV should never have any roof damage.
MALE*RN*777
Western MD, USA
Posted: 08/18/12 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like the membrane is bubbled in a few areas and should be cover under warranty. I would take it back or call the dealership and ask what you should do before applying any tape which may cause damage when they are looking at it to determine the cause. They may quick fix it with dicor caulking and have you come back.
03 Ford F150 XLT
Good-bye old friend --- 01 Coleman Sante Fe Pop-up
Hello new friend --- 09 KZ Coyote 23CR Hybrid
Me ,The Wife,The Boy,Girl 1 ,Girl 2
We are Blessed.
Retired Wileys
Lake Jackson, Tx USA
Posted: 08/18/12 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
Call the dealer and make sure that you don't void your warranty. Hope you still get to take your trip.
Herschal & Pam Wiley
2003 2500HD Crewcab Chevy
26H 2000 Prowler LS w/slide
Mr_MrsSchlepprock250
Archdale NC
Posted: 08/18/12 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
You have a trip planned,I would be at the dealer first thing Monday morning. If in fact there IS something poking up from within/under the membrane you shouldn't have to patch ANYTHING.I would inform the dealer you have a trip planned,have THEM patch it until they can get you in to replace the membrane as there are other bubbles showing in your pic.If it's not clear that it came from underneath,then it's yours to patch..JMHO...Phil
Phil&April
'99F-250Superduty4x4/CrewCab/7.3
'04Tahoe4x4/5.3
Sierra/Forest River 30'TT
We used to have Johnny Cash and Bob Hope,now we have no cash and no hope.
lots2seeinmyrv
Ocean Springs, MS
Posted: 08/19/12 06:06am Link  |  Quote  |  Print  |  Notify Moderator
Ditto...I wouldn't touch it until the dealer inspects it.
2010 Tundra TRD 4x4 Dbl Cab 5.7L V8 4.30 Max Tow 10,300 Payload 1,640 Class IV Hitch 1,030
Prodigy P2 - Blue Ox Sway Pro 10K/1K lbs
2012 Evergreen Ever-lite 29FK
TxTiger
North Texas
Posted: 08/19/12 08:16am Link  |  Quote  |  Print  |  Notify Moderator
X2
2000 F250, 7.3 PSD, 6 speed manual, CC, SB
KZ 27TH Toy Hauler, 5,700 lb dry weight/8,000 lb GVW.
2010 Triumph Tiger 1050
2012 Triumph America
2009 Suzuki DRZ 400sm
bsinmich
Holland, MI
Posted: 08/20/12 05:55am Link  |  Quote  |  Print  |  Notify Moderator
Eternabond willnot peel up or down. When putting it down you have to be very careful to not touch anyplace early because it sticks very very good. Once down it is there to stay. The cheap imitations that are out there will peel.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
atvaholic
Niagara Falls
Posted: 08/20/12 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks All.
I took it to the dealer today, and it was indeed a branch. You can see a line of sorts where the branch met the roof which scratched its way to the holes. There is nothing poking through from underneath. I guess this one was my bad. I need to be more careful.
The good news is they gave me a free strip of eternabond and I Patched it right there and then.
Now Im wondering about the rest of the roof that was scratched. It doesnt look too bad but the surface is a little scratched.
 > Roof Damage
