RV.Net Open Roads Forum: Class A Motorhomes: Winnebago slide adustment ?
 > Winnebago slide adustment ?
wbrowning
Southeast Texas
Posted: 08/19/12 09:21am Link  |  Quote  |  Print  |  Notify Moderator
My slide is dragging a little on one end attached is a picture can I adjust where red circles are to pick it up a little.
Gator48
Branford
Posted: 08/19/12 10:42am Link  |  Quote  |  Print  |  Notify Moderator
Yes you can, but it may not be your problem. Depending on your year and model you may have some poly rub blocks the the slides ride on. If they are worn out the slide will run lower in relation to the floor.
You really should replace them. With that said you cam "dial" in some height relative to the frame/floor with those adjustments. Just be careful as you will loose clearance at the top of the wall opening.
wbrowning
Southeast Texas
Posted: 08/19/12 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks I will look at blocks also.
