Cedarhill
Deep South
NetComrade wrote: . . . ground to black if looking at image of 7-way vehicle connector at the link above
Do not trust the color of the wires. Instead, look at the diagram of the connector and count from that to identify pins. Using a voltmeter, verify that there is battery voltage between pins 4 and 1 on the tow vehicle connector when the engine is running. If there isn't the problem is with the truck wiring. If there is, the problem is with the trailer wiring.
sch911
Rochester Hills, MI
NetComrade wrote: keatonb16 wrote: use a test light and see if you have power at the plug first. likely need the truck running btw
To clarify, I let the truck running for about 15min, but didn't seem to get any power in the TT. I'll use the volt-meter to test the plug. Sounds like I should get power.
Is there a battery installed in th TT? If not why not?
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
keatonb16
New Brunswick Canada
sch911 wrote: NetComrade wrote: keatonb16 wrote: use a test light and see if you have power at the plug first. likely need the truck running btw
did you not even read the first post?
his issue is that the battery is dead on the TT
2007 flagstaff 208
2010 Rav4 V6
squarles67
Orange, Texas
You have to install the fuse under the hood as already mentioned to get power back to the 7 pin. Had to do the same on my Chevy
keatonb16
squarles67 wrote: You have to install the fuse under the hood as already mentioned to get power back to the 7 pin. Had to do the same on my Chevy
we all know this. The Op hasn't come back to see if the test light showed power or not on the 12V pin.
That is the first step
NetComrade
Leesburg, Virginia
All, I will report later in the week, as my volt meter is at the TT.
I suspect it's the fuse. The truck did have a 4pin installed prior to the 7 pin being installed, but looking at the diagrams, that didn't actually have power. I understand I need to rely on diagram, and not the colors. I've never actually pulled anything yet, as my TT was delivered to the lot.
Don't have a brake controller, and my hinge is rusted in.. but that may become a whole other thread later.
Thanks Forum.
2010 Jayco 24fbs, GMC Sierra 2500HD
NetComrade
Leesburg, Virginia
There is no power like many of you suspected.
You are going to need to edit your forum preferences in order to see the images (if you can't see them)
I took pictures of my fuse box, and hope someone can help to determine which one should be plugged in. Nothing caught my attention in fuse list.
enblethen
Moses Lake, WA
This looks like the one under the dash. Did you find the one under the hood?
It could be post A.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
NetComrade
Leesburg, Virginia
enblethen wrote: This looks like the one under the dash. Did you find the one under the hood?
It could be post A.
D'oh.. I will look under the hood like I was instructed earlier.
NetComrade
Leesburg, Virginia
deleted
edited 08/30/12 06:51am by NetComrade *
