NetComrade
Leesburg, Virginia
deleted
edited 08/30/12 06:52am by NetComrade *
2010 Jayco 24fbs, GMC Sierra 2500HD
NetComrade
Leesburg, Virginia
ok.. let's try this again.. these are the fuses under the hood... still can't make out which one is missing for the 12v (battery) pin to work.
You are going to need to edit your forum preferences in order to see the images (if you can't see them)
Nothing caught my attention in fuse list.
enblethen
Moses Lake, WA
It should be either A or B. Fuses are in both.
I remember some the wire was not terminated on the stud. Look below the posts for a loose wire.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
NetComrade
Leesburg, Virginia
By A or B you mean Aux A or Aux B?
Fuse could also be dead. I'll check fuses and voltage.
I will also call the people that installed the 7pin, if I am unsuccessful in finding a dead fuse or a loose wire, as that was only a few mo ago.
jerb
phillipsburg, KS
i know they can hide them loose wires pretty good, should be one there somewhere!
2002 2500HD 8.1L/allison, 2004 KZ Durango
RCMAN46
NorthWest
To the OP. Have you checked to see if there is a wire connected to pin #4 on the truck 7 way? It may be possible who ever installed the 7 way did not provide for a battery charge wire. In 1998 which I believe we were told is the year of your truck not all of them had trailer wiring for brakes and the battery charge wire. It was an option in those years.
