bsandy56
Fl.
1998 Georgieboy 33 ft.chevy chassie. I have a one inch or better round rod U shaped in the front going to each coil spring. It isn't connected at the ends. Can any one tell me what it is for. It rattles some thing awfull.I have rags wrapped to quiet it down. I have a picture but don't know how to attach it. Thanks for any know how.
bsandy
enblethen
Moses Lake, WA
Sounds like it could be a sway bar that has been disconnected on the ends from the A frames.
Sway Bar
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
Matt_Colie
Southeast Michigan
I agree with enblethen.
If it has an end at each side of the vehicle, then that is what it is.
The only thing that might be tough is figuring out how it was supposed to be attached.
Most GM products use a link with rubber bushing at the ends. Somebody probably took the links off and forgot to put them back one. It is about a 12$ kit.
Matt
Matt & Mary Colie
A sailor, his bride and their black dog going to see some dry places that have Geocaches in a coach made the year we married.
bsandy56
Fl.
You are right enblethen, sway bar it is. Some one has taken the rubber bushings off or they fell out.Most likely taken off and not replaced. The rear sway bar is intact.I will try to order the bushings and get it back together.Thanks guys it is all clear to me now. bsandy
wolfe10
Better to go with polyurethane bushings than rubber.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
old guy
Oregon (pronounced Or e gun)
if you try to repair it yourself be careful. there is a lot of tension on that bar.
wolfe10
NO, as long as the two wheels are level with each other there is close to NO pressure on them.
A sway bar/anti-sway bar (same thing) can be lifted with your little finger if the attachment points are level. If out of level, old guy is absolutely correct.
I can/have replaced the end link bushings on my Roadmaster 1" sway bar (huge) with little effort and nothing but a couple of wrenches.
bsandy56
Fl.
Can not find bushings on the internet. Need bushings for 1 1/4 inch sway bar front end. 1998 Georgieboy 33 foot chevy chassies.
bsandy
enblethen
Moses Lake, WA
Measure bar closely and get urethane bushing as previously suggested. Look closely for two holes strapes on A frame. Need to get new bolts? they need to be high grade. Maybe 8s.
Remove some tension from front suspension may make it easier to re-install.
wolfe10
Contact Roadmaster for polyurethane sway bar bushings:
http://www.roadmasterinc.com/contact.html
I believe they have a kit with bushings, bolts, etc.
